Indeed
I see that Mouser now has White 1 and White 2 in stock.
May be slightly cheaper than L4P for those in the USA but unknown bin…
I could of sworn I read earlier in this thread that the new 1mm 4040 CULNM can be reflowed onto a XP mcpcb 3535? Before I attempt another reflow and heat this poor led up for the 3rd time can somone confirm 3535 mcpcb’s works?
Here’s the catch: not every 3535 board has the exact same solder pad dimensions. Reflowing 4040 leds works reasonably well on boards with electrical pads that are a bit thinner and thus wider apart. The amount of solder must be fairly precise too, and make sure you position the led very very well!
But yes, confirmed, I succesfully soldered the 4040 CULM on the stock 3535 board of a Micro-GT and have a working flashlight.
Nice, awsome and thank you. YOU DA MAN!! So excited, it’s going into a 126mm aspherical lens super short FL, pre lens w/collaniator and a small waiven collar.
126mm aspheric? Is this a home made job?
I purchased two of the CULNM1.TG leds a while back from L4P and only today had some free time to reflow one for testing but one of them has this thing that is looking like some defect around the die, is this normal for this led or not? I hope it does not have impact on performance or lifespan of the led.
I've seen that partial circle "trench" on many white flats1/2, it seems it's from some kind of tool/mold which protects die during pouring "white stuff" over package surface, it shouldn't have any influence on performance.
Ah, it seems like its not a big deal then, cool.
I just threw this led in a C8, driven at only 4.85A, centering was very easy but height of the reflector will be an issue, at the moment i have the same centering gasket i had for the black flat but it turns out this led wants the reflector a bit higher than the black flat, i think that it will need similar height of the reflector as the xp-g2.
Will test all this when it gets dark outside
It all depends on eachother, the thickness of different Mcpcb’s will differ , which allows more or less space in the head and that will affect the allowable thickness of the spacer and your focus, thus throw.
Focusing my white flat C8 took me more than an hour, but i eventually got it right.
Reaching over 200kCd on a standard Biscotti driver
This was taken before final focusing
Those are some excellent numbers, i hope that i will be able to hit that 200k number.
This C8 has slightly modified head and bezel, the reflector can sit and create enough pressure on the mcpcb without even needing of any type of gasket, before the mods the reflector outer lip was resting on the flashlight head and the reflector was not able to go all the way down, now without that problem i can play with the height of the reflector as much as i want, not looking forward to all that tho :confounded:
Yup, not sure what the lens was originally used for. Guessing a big rear projection TV? With a Olsen Flat black at 600 LM it did 2.6 MIll. LUX measured at 9 meters. And heres the kicker,2.6 mill with out the magical collar.
Meanwhile my collar will continue collecting dust until a new flashlight comes out
… With a Olsen Flat black at …
So you have some new friend called Olsen Flat who is black?
Anyone tested Osram “red flat” and “green flat” leds?
What would be the max current they could be driven at?
Size comparison: CSLNM1.TG vs CULNM1.TG vs CSLPM1.TG
I tested the green flat but not the red one
[image] [image] I received this brand new led from TheOnlyDocc, who managed to get some samples from Osram. Partnr is KP CSLNM1 F1, brightness bin 7N (lowest bin on the datasheet), chromaticity bin A. Datasheet here: https://www.osram.com/media/resource/hires/osram-dam-2494973/KP%2520CSLNM1.F1.pdf It is clearly the same generation as the White Flat, 1mm2 die, the die is a phosfor-converted blue led with a surprisingly uniform emission surface. The spectrum at 50mA (does not change noticabl…
The CULNM1 should have a lot of potential, since it has the size advantage of the boost HX but the smaller die advantage of the CSLNM1 which means less heat and more overdriving.
I can’t wait to test mine when I receive them
I wish I could buy them on a 32mm MCPCB for even better heat transfer, but noctigon doesn’t make one that fits this size, only XP size.
I can’t wait to test mine when I receive themI wish I could buy them on a 32mm MCPCB for even better heat transfer, but noctigon doesn’t make one that fits this size, only XP size.
Apart from the performance advantage, because of its size it is easier to center in flashlight builds, in a XP-L Hi host (there is many of them around) usually a slight reaming of the stock centerpiece does the job.
It is a pricy led though…
