Just received Trustfire F20, quick fix, quick tip
25 posts / 0 new
sb56637
sb56637's picture
Last seen: 13 hours 11 min ago
Hello all, today I received my Trusfire F20 from DealExtreme.  Just wanted to mention my experience... I was pretty irritated at first when I popped in the battery and found that it was flickering and changing modes by itself all the time.  Totally useless.  I suspected the worst, and was thinking about tossing it, but I decided to give a cleaning first just in case.  Good thing I did.  I just unscrewed it, and swabbed down all the surfaces I could reach with a cotton swab and toilet paper, no alcohol or cleaning fluid of any sort.  And that was all, I put the battery back and haven't seen a flicker or an unwanted mode change yet.  It didn't even look all that dirty, but that was the trick.
The light does NOT have mode memory. Worse yet, it always starts in the next mode. The low mode seems quite low. The beam is beautiful. It is very bright. And they just dropped the price to $13.06, after I bought it of course.   I'll do a full review next week.
Edited by: sb56637 on 02/14/2012 - 08:18 Reason: sb56637 replaced budgetlightforum.cz.cc with budgetlightforum.com via Scanner Search and Replace module.
brted
brted's picture
Last seen: 5 months 4 days ago
Glad you were able to get it working better. Sometimes the light has to stay off for 30-60 seconds for the last mode to be remembered.
sb56637
sb56637's picture
Thanks for the tip, I remember reading that, but I think I left it off for a at least a minute, but no luck.  I'm quite thrilled that my cleaning worked though, I can't believe that was so simple.
alfreddajero
alfreddajero's picture
Last seen: 11 months 3 weeks ago
Cool cant wait for the review buddy.  Hows the build quality of the light,  i also hate that flickering issue.  You should make it a point to clean the light right out of the package.
With Darkness, there will always be Light.
sb56637
sb56637's picture
I was going to slam it for build quality due to the mode changing, but if that problem is really eliminated, then the build quality seems quite good.
alfreddajero
Just to let you know even lights that cost an arm and a leg need to be cleaned right out of the package.....Dont know if you recall about the Nitecore D10 issues with the switch ring and piston getting stuck because of that sucky blue lube that they used.  When i finally got mine i spent some time cleaning it before i devirginized it with a nimh cell...lol.
sb56637
sb56637's picture
Huh is that right?  It's funny, this light didn't even look dirty.  But the difference is just like night and day.  If that's all it takes, I can handle it.
alfreddajero
Sometimes bits of machining spurs gets in the threads and can cause issues.  I make it a point to tighten the switch retaining ring, make sure that the pill is clean and tightened, and clean all the threads with alcohol and relube.  I dont care how much the light cost me its just good practice.
sb56637
sb56637's picture
Yes, you're right.  The problem with the design of the Trustfire F20 / Akoray K-106 / Uniquefire AA-S1 is that it unscrews at the head, not at the tail.  So it's hard to get in there with tweezers.
alfreddajero
I use something like this.....there long enough to get in there.
http://www.shiningbeam.com/servlet/the-135/Stainless-Tweezer/Detail
sb56637
sb56637's picture
Ok you're right brted, this light does have reliable mode memory, but it's just a very long delay, more than 60 seconds.
alfreddajero
So how do you like the light now....has it been serving you well.
sb56637
sb56637's picture
I'm quite happy with it now, thanks for asking.  Quite a nice tool for the current price of $13.06.  Definitely worth adding to your list.  I'll try to review this on Monday.
Something else I just learned, this light model does unscrew at the tail, I can't believe I never noticed until now.  The seam is at the very tip of the tail right around the edge.  It's actually sort of a pain to unscrew because the clip wants to turn.  I'd still recommend to just change the battery by unscrewing the head.
alfreddajero
Cool just make sure that the switch is tight and that the inside of the switch boot is clean.  Now how about them rechargeables, you must be going through alkies left and right lol.
sb56637
sb56637's picture
alfreddajero wrote:
...you must be going through alkies left and right lol.
Nope, that's why I like efficient flashlights with a low mode, the batteries last forever! :)  But yes, I really should get some rechargeables...
alfreddajero
Sorry man...i'll stop harrassing you about the batts.  I like to use the low mode as night lights for the kitchen and the living room.....so when the power goes out im not left in the dark.
sb56637
sb56637's picture
Hmmm, it is starting to change modes on me again, it has to do with vibrations.  A vigorous shake makes it change modes, or sometimes rotating it makes it change modes.  Any ideas if I can salvage this somehow?
alfreddajero
Did you check the retaining switch ring......it might have gotten loose.
sb56637
sb56637's picture
I checked it the retaining ring, it feels tight, but it doesn't seem adjustable or lose.  It's not a traditional tailcap, it's very thin.  The LED module was loose in the head, and I do need to tighten it better into the head, but I don't have any tools fine enough to get into the dimple.  But when I shake the light I don't feel the LED module rattle now.  I tightened everything and wiped it down again, and it seems good again, but it has me wondering now...
alfreddajero
It might have been the LE......was'nt making proper contact causing the craziness in modes.
sb56637
sb56637's picture
OK I really do think I got it fixed this time... Before the light module was actually making a clunk sound when I shook it lightly, that was almost surely the problem.  So I finally found a 0.5mm mechanical pencil with a metal sleeve in the point and stuck it in that miniscule dimple and I got it nice and snug now.  (I feel like such a craftsman now  cheeky)  And now I'm walking around with the light and shaking it and bumping it and it really does seem to be fixed... I sure do hope that's all it was because I really like this light.
alfreddajero
Good.....you have to remember and make it a habbit to check them......just like a real car the lights need to be taken care of too...lol.
sb56637
sb56637's picture
I guess so... I really think that was it.  It seems to be standing up to my gentle torture test.  Thanks for the tips Al.  Here comes my detailed review in about ten minutes...
alfreddajero
Cool, cant wait.smiley
sb56637
sb56637's picture
