Almost any good high power LED such as 219F, 319B, XPG3, or XPL2 will certainly beat mid power LED efficacy. In real world application the cost of high power LED just can’t compete with mid power LED when it comes to sustained long run total system efficiency. Unless you are willing to invest at least 10x the investment cost.
Checked the Esttool and that’s not the case. This makes it even better! So the real drawback is only luminaire size and optic compatibility. This fact, makes me want to make a home lighting with 150lm/watt operating efficiency!
Check this:
Medium power LEDs go to very high efficacies like 228 lm/W of CRI80 from Everlight 62-227ET/KK7D (even more when the LED is underdriven). I’m yet to see this beaten by high power ones.
According to Led4Power:
Here we have 199 CRI80 lm/W at 65 mA for NF2W757GT-V3F1. Not bad bat not special. In CRI90 the same model does 165 lm/W, compared to ~200 lm/W of Samsung and Everlight.
But in what I do now I’m interested mostly in CRI90 lm/$ vs. lm/mm² sweet spot. Efficiency matters but is secondary. Overdriven Medium power clearly dominates lm/$ while overdriven CSP high power clearly wins lm/mm². Interestingly, CSP medium power should be the sweet spot but I failed to find any really cheap yet good top-emitting CSP LEDs (top emission is important for dense packing).
So far I’m with medium power because while I’m not really happy with lm/mm², it’s good enough - and price is much lower.
Optisolis is very good and if I use it to estimate NF2W757GT-V3F1 performance I really like the results. Others could be better but reasonably-predicted beats wildly-predicted so this is my top pick so far. And learning that I can expect to see it tested was really nice.
One idea that I have for a future project is 200 lm/W CRI90 lantern. 1/4-1/3 of LT1 size, same runtime. Different beam for different uses so not a direct competition though. 200 lm/W only on low, stretching that to 200 lm/W high would be in order of $100 per light.
Medium power LEDs seem like the only option to deliver this kind of efficacy.
Don’t forget to add 85% optical efficiency and 95% electrical efficiency in the equation. I always use 85% OE and 95% EE for high end design and 85% OE and 85% EE for normal design. 150lm/watt system efficiency is realistic with 170lm/watt LED level efficiency.
And with such low power density you can put your usual thermal transfer anxiety to sleep.
I didn’t forget to take optics and driver into account. 200 lm/W end to end is at the edge of feasibility, depending mostly on how exactly do these LED behave when underdriven. I also tend to use 95% buck driver efficiency but for this light I assumed more efficient optics.
And thermals are actually an attention-worthy deal. Mere 5% efficiency drop due to heating up is a big deal.
More on the 200 lm/W…I did the calculations yesterday and several days ago, now I write from memory so I may be off.
Samsung and Everlight do 230 lm/W at 10 mA.
With very low current you need much less diffusion. And the lantern doesn’t harve to be completely glare-free; low-glare may be OK.
So…
230 lm/W base, efficient buck driver, AR coated lightly patterned glass cover. Luminit claims their diffusers to be 95-98% transmissive depending on angle, so probably more like 96% overall. I’ve seen other makers claiming 94% and used that. So 205 lm/W. Now…
thermals reduce it
light at very wide angle which doesn’t hit the glass is a further tiny reduction
some of the light reflected off diffuser and which didn’t hit the glass will be recycled by white head interior or by phosphor
So…as I said, 200 lm/W is at the edge of feasibility, may or may not be doable.
Note that about 20 LEDs give nice about 100 lm when driven at 10 mA each. And 20 MP LEDs doesn’t cost arm and leg.
200lm/watt is definitely attainable these days. My last citylight project requirement was 150lm/watt with 3000K 80 CRI at system level.
Although we got beaten by Hori LED for the price, that was quite a learning process. And that has made me respect mid power LEDs more than before. I used to skip all low and mid power LED every time I browse manufacturer’s website, not anymore.
Well now back to work on the 4x4 and/or 3x3 E21A mcpcb and RRT01 mod I think the mcpcb would be popular since it would be a direct swap into so many XHP70.2 lights in existence.
Is there any way to have two isolated sets of LED’s on one board? I would like to have adjustible color temperature, so have alternating rows of 5000k LED’s and alternating rows of 3000k LED’s, where all the 5000k can be controlled separately from the 3000k.
Any plans to bring such packages (more particularily the Optisolis based ones, as tested bu Maukka) in a complete bulb format (E27 based for instance)?
Yeah, I’m thinking to make circular DIY kit for light bulb retrofit. But the problem is in choosing universal sizing for the MCPCB. Would you like to participate in the research?
And one more thing: almost all light bulb’s diffuser are glued to the base. Not so easy to open for general public
At the moment I can't think of a better dream solution than using R95 Optisolis to light my rooms. It's your fault, since you made me discover Jetµsolis!
So, you bet I'd be glad to help to find a solution to mod/create our own bulbs!
I know we have Bocian here that is creating some nice custom E27 bulbs, based on Citizen LEDs. He might be of help. Maybe by joining each of our BLF's talent we can build together the ultimate bulb.
