I want 1 or maybe 2 FW3T stonewashed 100%
I am interested in one. I don’t have a titanium light.
Will buy one light 100% - SST20 4000K
Thanks!
I “may” be interested in one… but not sure. Maybe if I know the exact final prize
I am interested in 1 FW3T stonewashed SST20 OSRAM
Neal had written about the SST20 - maybe a missunderstanding
they will test the full Ti of course and maybe dactivate the FET if needed too
I want 1 FW3T stonewashed 100%
I am interested in a FW3T stonewashed (SST20).
That should be great option for modders, 219B for example
The SST-20 5000k/6500k is the most efficient in a light like the FW3A.
Actually I think XPL HI is the most efficient (in terms of lumens per watt). It produces more lumens and less heat than even the cool white SST-20.
The cool white SST-20 is throwier though. In terms of lux per watt it might be more efficient.
No, it’s actually more efficient.
Up until 5A, the SST-20 is more efficient than the XP-L HI.
Is it possible to buy a non stonewashed FW3Ti?
Interested in one with HiCRI Samsung LH351D
Surprising result. I had a lot of respect for SST-20 and now I have even more.
Note that TA has tested V2 bin while the top one from Hank is V4 and normally V3.
Also, TA lumens may be significantly different from maukka ones, either higher or lower.
Assuming TA lm = maukka lm V4 would be more efficient in FW3T Turbo. But without this assumption it’s not so sure…
I think it would be interesting to compile some direct comparisons…
Noooooo!
Or at least make it an option.
I am interested in a FW3T stonewashed, only if FET is NOT deactivated…
Not sure we can generalize a whole lot from that since the testing was done by 2 different people. Were they both using Maukka calibrated spheres?
At the time, no.
Maukka is more precise and accurate, and usually has lower numbers than TA.
Interested in 1 FW3T Stonewashed.
Warm white (XPL-HI 7A, SST-20 3000K - whichever is available), but can emitter swap if not available.
