Current list with ordering information and also shipping
follow here the progress of your order and check if the order contains all you need
Tracking website
Tracking website
TA Driver sizes
12mm, 15mm, new 17mm for 2 S ind. pad, 3 channel (Bistro HD), 17mm 10AMC, 17-19mm
20mm, new 20mm 1S/2S LX driver, 20.5mm Astrolux S42
21mm, new 21mm Skilhunt H03, 20-22mm
24-30mm 1S,24-30mm Convoy L6 new 2S version without AMC for more reliability, also added 2 switch LED support, 28-30mm all AMC, 38,5mm Cuoroi D01
42mm Niwalker BK-FA30S and Thrunite TN40/42 1S, (2S), 46mm TA Haike Lite, new 46mm
47,5mm Astrolux MF01(S), 47,5mm BLF Q8, new Q8
My other Buck/Boost driver, Tail FET, and lighted side-/tail switch sales
LM3409 based buck-drivers
20mm, 21, 22mm new more efficient MOSFET and minor changes
23mm for Klarus XT11/12GT running 2 18350s for Oslon BF or other 3V LED, 24mm
new 30mm for Convoy L6 more efficient MOSFET
new TN40S/TN42 for higher currents, Niwalker BK-FA30
new 46mm GT and MT07/09S
Astrolux MF02(S), new Astrolux MF01 Buck
Acebeam X45 and K65 (with switch board)
Boost drivers:
UV-C and UV-C+UV-A drivers
standard is 500mA 7.8-8V for Klaran 275nm LED, 17mm 2 AMCs for 365nm LED, 20 and up to 4 AMCs for UVA
17mm UVC, UVC+A
20, 21, 22mm UVC+A
lighted tail boards like Convoy S2, C8
Remote FET switch/1 mode DD for Tail caps
UI and config
TA drivers
Mode groups
NarsilM v1.2
Connections:
older boards
new boards are marked as my side switches
S-Switch
G-Ground
L-Lights MCU controlles
some drivers got LS for permanent LED light
*also most high current new drivers got filtering for better LVP, but this makes re flashing impossible
there is a solder bridge you can open next to small C3*
2S boards are now available in FET+x+1AMC or FET+1+indicator LED output, by adding solder bridges to change pin out
MF01 v2 TA MCPCB Mod
reserved
Interested for my two AT40s. I’ve never bought on here before and I’m not sure how it works and I didn’t see a sticky about it.
I have a reverse clicky 14500 light that could use a new driver. Now it’s 1-mode on/off.
What options do you have on a 15mm board?
Is it a FET driven board or purely regulated? I don’t need Turbo mode, i need long runtime
15mm is FET+4+1
Shipped today 4 orders
Could I get two 17mm drivers please, soldered wires and short spring please.
It seems I ran into a big problem
The latest drivers I built with new batch of AMCs get faulty
they do not shut down complete after the AMCs got first time used
more use and it seems more get faulty or one more bad
Those were ordered from LCSC, I build now 7 drivers in a row and all get faulty
Also very low moonlight levels do not work with them
Just hooked up a 22mm “D4” driver. It’s in the green one in the middle.
Anduril Runtimes at level 5/7 stepped ramp (should be running on the FET in the stock drivers)
The black D4 (stock driver - XP-G2): 3:15
The green D4 (LX 22mm FET+6+1 - 219C): 2:10
The silver D4 (stock driver - XP-L HI): 2:45
I know the 219C are inefficient, but the stock driver lasts an hour longer before stepping down.
Shouldn’t the FET+6+1 driver with the AMC’s last longer at high output?
If it lasts less long there is a simple reason it’s that it draws a higher current,
you can’t assume they draw same current as they have different ramping tables
Just took it apart. Looks like I also made a mistake. I only used 20AWG wire from the driver to the MCPCB :person_facepalming:
Lexel, do you produce any drivers in the 10440 size range - say, 10mm or 11mm? I don't see any listed below 15mm, so I assume not, but I thought I'd ask anyway.
12mm with 1mm copper rim
Hi. Sorry if is not the best way to ask. I am looking to drive 3 osram oslom luw with 15 volts. The driver could be square or round. I can glued with ceramic epoxy to a heatsink. I need 4. Thanks in advantage.
How do I go about ordering a driver board?
Interested in board for MF02, would it have to run standard battery config?
I have an extension tube on order.
I have the Buck that is 4S only with 12V LED
I know many have seen that I had huge delay in last 3 weeks literally came not to forum orders
I was barely getting enough time to deal with commercial stuff with Fireflies and Astrolux for example
last 2 days I was so busy completely rearranging my living room to fit a 190×70cm working table to get enough space to work more efficiently on flashlight stuff,
my couch, couch table, parts of the furniture and the cat tree were literally packed with flashlight stuff, also window and floor with a lot of stuff standing around everywhere
Also have at the moment 12 young cat babies that need to be dealt with to get them sold that eats time as they are now 9 and 10 weeks old from 2 cat moms
Good to hear. Did you also sort out the faulty AMC’s ?
I’m building a S2+ that needs a 17mm driver.
What’s the difference between the “3 channel (Bistro HD)” and the regular “TA 17-19mm” design?
The first seems to have multiple FETs ?
What would you recommend? It going to be a single emitter. Aiming for longest runtime, no hotrodding
