Maybe we could include a flashlight in it? Maybe package the charger as Q16 with a set of adapter sleeves / blocks for smaller cells so it’s actually a good flashlight?
Actually…I was thinking along the same lines. Normally I’d rather wait longer for a charge than listen to noise. But then - high discharge rates are likely to need active cooling.
And I sure think that some others would prefer faster charging to silence - that’s why I didn’t speak up before.
Everything sounds great and I can’t wait for this idea to materialize! My only suggestion is to put a big high-quality fan on it, which must be quiet and cool the charger and the batteries.
Actually the "wireless" capabilities of a device are much more likely to stop working, cause problems, than a cable. A cable is less 5exy but it is will be more trustable.
I've encountered enough problems with wireless devices.. (that need to connect with other things)
But interesting idea for doing a BLF charger. I'm with Djozz, keep the UI easy..
Higher discharge current like 10A+ the charger will need to dissipate around 40W of heat so on in that case we need fan cooling with good heatsink. Also If we want to charge and test battery in the same time with higer currents that also may be a problem for charger to dissipate that heat.
Please make the slots big enough so you can remove cells without having to kind of ‘pick’ at them from top or bottom with fingernail and risk tearing the wrap.
I like a display for each slot, so when I charge cells that were in the same device, I can immediately see that they all took about the same mAh. I guess I’m too lazy to remember the numbers while cycling through them with a button.
>2. Charging/discharging graphs to a USB driver.
How about logging to microSD or SD instead? Then you can just leave a card in it and get the results and plot them when you want. No cable, drivers, app, etc needed. Easy to leave one living in there so you can check later if something unexpected happens. A clock might have to be added.
Considering the price of the MC3000, this is a lot of features to be asking for at the price currently considered in the OP. Even if BLF were to do all of the hardware design and write all of the software, I'm not sure it would come in for $45.
My charger is a LiitoKala Lii-S1, it is exactly what I needed. you put the cell in, it charges, I can remove whenever I feel the voltage is right.
It was on sale on AE a while ago, holding up since then.
I agree with this. Also translucent plastic colors would be nice, like what was popular with electronics in the past. Then we can see all the internal parts. Maybe even put some LEDs inside so it can work like a night light? I don’t know if that is too crazy of an idea for a charger.
Make alarm sound when charge is at FUll 100%, Sometime I forget at what time my cell will full.
The also so have very good analysis in determined expected time of fully charge.
Able to counter interupt power supply such as condition when there is sudden voltage drop or cut-off, charger should pass stress test and continue process properly.
Why not use the C-rates or atleast show the C-rate as we choose current selection. E.g when we choose increase the current, the C-rate display also increases.
Usb output for charging mobile phone since they are Li ion cell too.
Hope to see high accuracy of this charger in measuring internal resistance and temperature.
Hope not to be expensive I mean way toooooo expensive that price that fold 3x 5x…
There was no reason for the MC3000 to be so expensive in the first place except that there was nothing quite like it at the time, it was a very botched attempt though, both software and hardware.
I was under the impression it had undergone a revision or two and was a lot better now... but then again, I don't have $100 for another charger... that's flashlight money!
Love it. Two of the “must have” features for me is adjustable current and adjustable termination voltage. Great for extending the life of cells.
I’d rather drop some of the fancier features if it keeps the price down. Otherwise, the SkyRC MC3000 already exists for a high price.
#1, #2, #6, #11, #13 are the most important features.
#4, #9, #10 are nice to have, and shouldn’t add to the cost.
is nice, but might add the cost. Probably worth keeping if it’s not too much more expensive, though.
The rest can be dropped if it keeps the price down. Set the max current at 1A per channel, and you won’t need fans, temperature monitoring, etc. Maybe 2A if only 2 slots are used.
Oh, maybe drop LiFePO4 support if it causes safety-issues with automatic restarts, as another poster suggested. Most people probably just need NiMH and 4.2v lithium-ion support.
