1. Any wireless protocol will not be included for cost and reliability reasons. A direct USB connection to a PC would be best.
2. Yes, that would be good.
3. That would be good, but I’m lazy.
4. Highest cell voltage/internal resistance USB connection.
5. Standard 5,5*2,5mm DC jack input.
6. Yes.
7. Oh that’s easy. Until the charger is completely off, every charge cycle will go like this:
Cell 1-2-3-4
Cell 5-6-7-8, and so on.
8. microSD card functionality would be good for automation, but USB data output is still better, I agree.
9. Case color options would go like this: Black and white.
10. Display. Large IPS display it is.
11. Good UI.
Everything else has already been said, but no Android functionality is to be included for the reasons you mentioned.
With every feature included here, 49$US GB should be doable.
Interested but if possible not with MiBoxer which tends to sale on amazon with coupon for amazon US most of the time, they don’t care about the rest of the world.
I’ve limped along with an aging Nitecore Intellicharger and have had to wrestle longer cells into the slots. Keeping my 26650 cells in the slots and touching the terminals has been a delicate operation. It’s like I need the dexterity of a safe cracker to keep them in contact. It doesn’t charge some of the LiFePO4 cells I have and the flashing leds only give me an estimate about how charged the cells are at any one time.
Still, I’ve hung onto it and have waited for a reasonably priced, quality charger with an easy to operate setup. Just like my lights with Narsil and Andruil, I like the flexibility, but I can operate it easily without thinking. I hope that in the rush to get a “pie in the sky” charger, it is easy to use.
I’m glad this thread was started. I’ll keep a close eye on it for the future.
BlueSwordM, this is a great idea, and, as a charger-aholic, I’m in for certain, regardless of cost. To me, some important criteria, which have only been mentioned in passing so far, are: quality, precision, and accuracy. Unlike a fun, hotrod flashlight, a charger serves only as a tool, not a toy. No one is going to start modding chargers as a hobby, so it needs to be good out of the box.
The object, I think, is a reliable charger that charges accurately at the desired rate, terminates accurately at the desired level, and does so in the desired amount of time. I think an automatic muggle mode will be fine for many people. But there are tradeoffs between current, voltage, time, and battery longevity, and I want to be able to determine the tradeoffs myself. This is what makes the MC3000 such a great charger, in spite of its convoluted user interface. Charge termination for NiMH batteries is an example of an area where most chargers are both woefully imprecise and inflexible, as you can see from HKJ’s reviews.
Speaking of which, you might want to see if you can involve HKJ, and also Kreisl, who helped develop the MC3000 with SkyRC.
I understand, BlueSwordM. One feature request I would have is the ability to create custom programs, as with the MC3000. This has turned out to be the most important feature of that charger, for me. It saves a lot of time, of course, but, even more important, I don’t have to remember all the various settings for different cells and functions. I have a chart which shows the settings for each program, sorted by cell type and size, so all I have to do is look at the chart and punch in the program number. Once set up, the MC3000 actually became the easiest to use of all my dozen analyzing chargers.
If you throw too many features into this project, you risk
(1) Making it too complex to use,
(2) Making it too expensive,
(3) Making it buggy with features that don’t work properly,
(4) Making it a niche product that few people will buy.
Honestly, I’d be happy with a Nitecore SC4 that had a settable charge termination voltage, and lower default charge rates. Nothing else needed.
Or a Liitokala Lii-500 with settable charge termination voltage. (The Lii-500 has a discharge capacity function already.)
Perhaps approach a company with something very similar already, and ask them to add the extra couple of features into an existing product. That should make it easier to build, and less prone to quality problems.
I was aiming for 100% increase in slots and a 50% increase in max current. 2x 4, 1.5x 12.
To be perfectly honest, I’d be as happy with the original 12 amps split across 8 slots as I would with 16, 18, or 24 total amps split across them.
A complete wishlist item, but hey - this IS brainstorming, right? :+1:
At least this is a more practical idea than adding 1 or more cheap accessory sidecars containing their own charge circuits but being controlled by the UI in the master unit.
I’ve been using a Nitecore D2 I got on clearance for $13. It does everything I need or want in a charger, and by sheer luck, it’s calibrated 0.02V low so it stops right at 4.18V. Pretty much ideal, as far as I’m concerned.
Also a couple MC1 chargers, for travelling. They were like $3 or $5 or something; I forget. And the BLF Lantern is nice if I want to charge a set of 4 cells.
Wow, that’s a name I haven’t heard in ages.
New BLF members probably don’t know the history there, and it’s pretty much erased from the internet now, but… there’s only one answer to that question, and JamesB nailed it.
