I also ordered an EDC05C May 24 and it is still processing.
Haikelite did lower the Current to 8A and remeasured the FT04 with 2500 Lumen
Astrolux FT04
SST-40-P2 2500LM
1000M Long Throw Searching Flashlight
2A Fast Rechargeable
my Code: MFT04 YOUR PRICE: $37.99
Hello my dear friends!
Today i present you Sofirns 18650 driven, 1200Lumen Headlight wit USB charging: the SP40
Get it on Amazon :
.COM: https://amzn.to/2LKlFvz
.DE : https://amzn.to/2G8UaZc
banggood Summer Prime Sale - please start here: (5 days left!)
https://m4dm4x.com/do-not-miss-summer-prime-sale-banggood-com/(go down to the Sofirn -20% Link and use the code there to get it for just $17.59 !!)
Amazon.DE : https://amzn.to/2G8UaZc
use Code "SofirnSP40" for total 25% OFF (15% there + 10% with code)
This is the only real problem I have with the FT04 so far. "Only" 2 amps is not a big deal to me, but.. Leave charging completely out, or use a 'normal' connector. My true feelings about being saddled with special type of charger for an otherwise drool worthy light are most likely against the BLF TOS... :FACEPALM:
Hello, do you have a coupon for Lumintop Tool AA ?
of course ;)
please PM or mail me the link to the Tool AA you want (color , V2.0 or not)
i get you the best deal
Any code for Lumintop C01 please?
sure
i ask banggood to remove the PROMO tag, so it can work
just check my deals list on my blog ;)
€dit:
banggood removed the promo limitation ;)
M4X I didn’t find something for C01
Hallo mitnand!
Heute bis kurz vor 15 Uhr im Flashsale bei Amazon.de
Sofirn SP31 V2.0 für €23,99
Cree XPL HI LED 1200 Lumen
7 Modi mit Akku und Lader
Mein Link: https://amzn.to/2jP2uW5
New deals: Niwalker MM6S 18650+21700 & BK-LB11SV2 & BK-LR7SV1 & MF5SV1 Mini
I cannot post the prices (search engines) so just try my codes to get the LOWEST prices for those Flashlights! ;)
OR get them prices in my deals list!
please follow the links below to the shop for detailed description
Niwalker MM6S (18650)
6x XP-L HD/Nichia 5500lm/3500lm
USB Rechargeable EDC Flashlight
CODE: MM6S
Niwalker MM6S (21700)
6x XP-L HD/Nichia 5500lm/3500lm USB Rechargeable EDC Flashlight
CODE: MM6S2
and
Niwalker BK-LB11SV2
2650 Lumen 1900m Long Throw
18650 Flashlight IPX7 Waterproof
CODE: MLB11S
Product Description
Niwalker Vostro BK-LB11SV2 Long Throw Search Light 2650 Lumens, 1900 meters throw distance, double switch design
(Choose the main switch is on the left or right, base on your operation habits, pls remark when you placing order!)
and
Niwalker BK-LR7SV1
18650 Flashlight Magnetic Control
CODE: MLR7
Features:
● One of the most powerful long throw search lights on the market.
● Maximum output up to 2650 lumens and an ultra-long beam distance of 1900 meters.
● Highly efficient constant current design offers maximum output and runtime
● Magnetic ring control switch allows you to select desired output easily
● Advanced thermal protection circuit prevents overheating
● Unique smooth reflector design provides great throw beam distance and beam pattern
● Aircraft grade aluminum, mil-spec hard anodized for maximum wear
● Toughened ultra-clear tempered glass lens with anti-reflective coating
● Large cooper heat sink pad for superior thermal conductivity
● LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time.
● Front red/green LED for easy following.
and
Niwalker MF5SV1 Mini
15000 Lumen High Power Spotlight 18650 EDC IPX7
Waterproof Mini Torch
CODE: MMF5
Features:
Highly efficient constant current design offers maximum output and runtime,Maximum output up to 10000 ANSI lumen.Waterproof & Shockproof- The LED tactical flashlight made of Aircraft Grade Aluminum, with a camera screw hole in the rear of the flashlight; delicate protection, IPX7 waterproof design,1.5 meters shock proof.Smart triple Multi-function clicky side switches.Advanced thermal protection circuit prevents overheating Unique smooth reflector design provides great throw beam distance and beam pattern,intense beam up to 850 metersToughened ultra-clear tempered glass lens with anti-reflective coating.Large cooper heat sink pad for superior thermal conductivity.LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time.
banggood added something nice:
HTP WORKS
Self Illuminate Turboglow Palace Lantern Bead
you can find the deal in my list
the summer sale deals have not expired yet !!!
for example Haikelite MT40 with 8000 Lumen for ONLY $41.99!! using the code : BGSM30%
check the other deals TODAY! – they can expire every minute….
-> members can look in my deals list too (if its not a “Promo” item)
EXTRA 30% OFF for:
ASTROLUX – CONVOY – ROFIS – SKILHUNT – LUMINTOP – HAIKELITE – SUNWAYMAN – Archon – XTAR – FITORCH – THORFIRE – DQG
AND
EXTRA 30% OFF for:
JETBeam – Wuben – NEXTORCH – NITECORE
AND
Lumintop Turboglow Glow Gasket For FW3A & Carclo 105XX just $6.99
I was able again to get a GREAT DEAL for my community!
Banggood.com just listed the
Lumintop 2×19.7mm
Self Illuminate Turboglow Glow Gasket
(Most Triple Optic Light Flashlight)
SPECIFICATIONS
Brand: LUMINTOP
Material: TurboGlow (Best now)
Color: Green, Yellow, Lava, Purple (Other colors out of stock now)
Fit: Carclo 105xx Optic. (10507/10508/10509/10510/10511) triple leds
Fit for most Triple optics lights: TLF/BLF FW3A, barrel,hanko,boss,okluma,reylight.
Note: These are NOT 3D printed and will NOT melt warp chip crack or deform inside the head of your light
to start banggood sells them for $10.90 instead of $13.95
M4DM4X.com fans & friends get it for US$ 6.99 !!
just use my code: MGLOW and my LINK
(only in July!)
one more thing:
share my pages and let your friends know where to get the best deals ;)
use my links to generate traffic even when you do not buy! (that results in better discounts!)
subscribe to my youtube channel and facebook page
mailcall!
Lumintop FW3C + mounting Turboglow Gasket and Button
Hello my dear friend!
Today a beauty arrived! So i had to show you!
You can get your FW3A/C here:
https://m4dm4x.com/fw3c-and-fw3a-sst20-4000k-available-2/
FW3C copper (nichia/SST20/XP-L HI) + FREE holster = $60.90
veröffentlicht am 24. July 2019 in flashlights von m4d m4x
Banggood listed the copper version of the hot selling FW3A with 3 LED versions available and adds a FREE Holster (limited supply!)
Use this link and take care the gift is checked
– then go to the cart and use my code to get it for US$ 60.90!
(ask me or just look in my deals list)
I got a bunch of deals for the new listed Trustfire flashlights.
just click the link or picture to get detailed info at the shop!
