This is the only real problem I have with the FT04 so far. "Only" 2 amps is not a big deal to me, but.. Leave charging completely out, or use a 'normal' connector. My true feelings about being saddled with special type of charger for an otherwise drool worthy light are most likely against the BLF TOS... :FACEPALM:
Hello, do you have a coupon for Lumintop Tool AA ?
of course ;)
please PM or mail me the link to the Tool AA you want (color , V2.0 or not)
i get you the best deal
Any code for Lumintop C01 please?
sure
i ask banggood to remove the PROMO tag, so it can work
just check my deals list on my blog ;)
€dit:
banggood removed the promo limitation ;)
M4X I didn’t find something for C01
Hallo mitnand!
Heute bis kurz vor 15 Uhr im Flashsale bei Amazon.de
Sofirn SP31 V2.0 für €23,99
Cree XPL HI LED 1200 Lumen
7 Modi mit Akku und Lader
Mein Link: https://amzn.to/2jP2uW5
New deals: Niwalker MM6S 18650+21700 & BK-LB11SV2 & BK-LR7SV1 & MF5SV1 Mini
I cannot post the prices (search engines) so just try my codes to get the LOWEST prices for those Flashlights! ;)
OR get them prices in my deals list!
please follow the links below to the shop for detailed description
Niwalker MM6S (18650)
6x XP-L HD/Nichia 5500lm/3500lm
USB Rechargeable EDC Flashlight
CODE: MM6S
Niwalker MM6S (21700)
6x XP-L HD/Nichia 5500lm/3500lm USB Rechargeable EDC Flashlight
CODE: MM6S2
and
Niwalker BK-LB11SV2
2650 Lumen 1900m Long Throw
18650 Flashlight IPX7 Waterproof
CODE: MLB11S
Product Description
Niwalker Vostro BK-LB11SV2 Long Throw Search Light 2650 Lumens, 1900 meters throw distance, double switch design
(Choose the main switch is on the left or right, base on your operation habits, pls remark when you placing order!)
and
Niwalker BK-LR7SV1
18650 Flashlight Magnetic Control
CODE: MLR7
Features:
● One of the most powerful long throw search lights on the market.
● Maximum output up to 2650 lumens and an ultra-long beam distance of 1900 meters.
● Highly efficient constant current design offers maximum output and runtime
● Magnetic ring control switch allows you to select desired output easily
● Advanced thermal protection circuit prevents overheating
● Unique smooth reflector design provides great throw beam distance and beam pattern
● Aircraft grade aluminum, mil-spec hard anodized for maximum wear
● Toughened ultra-clear tempered glass lens with anti-reflective coating
● Large cooper heat sink pad for superior thermal conductivity
● LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time.
● Front red/green LED for easy following.
and
Niwalker MF5SV1 Mini
15000 Lumen High Power Spotlight 18650 EDC IPX7
Waterproof Mini Torch
CODE: MMF5
Features:
Highly efficient constant current design offers maximum output and runtime,Maximum output up to 10000 ANSI lumen.Waterproof & Shockproof- The LED tactical flashlight made of Aircraft Grade Aluminum, with a camera screw hole in the rear of the flashlight; delicate protection, IPX7 waterproof design,1.5 meters shock proof.Smart triple Multi-function clicky side switches.Advanced thermal protection circuit prevents overheating Unique smooth reflector design provides great throw beam distance and beam pattern,intense beam up to 850 metersToughened ultra-clear tempered glass lens with anti-reflective coating.Large cooper heat sink pad for superior thermal conductivity.LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time.
Hello my dear friends!
banggood added something nice:
HTP WORKS
Self Illuminate Turboglow Palace Lantern Bead
you can find the deal in my list
the summer sale deals have not expired yet !!!
for example Haikelite MT40 with 8000 Lumen for ONLY $41.99!! using the code : BGSM30%
check the other deals TODAY! – they can expire every minute….
-> members can look in my deals list too (if its not a “Promo” item)
EXTRA 30% OFF for:
ASTROLUX – CONVOY – ROFIS – SKILHUNT – LUMINTOP – HAIKELITE – SUNWAYMAN – Archon – XTAR – FITORCH – THORFIRE – DQG
AND
EXTRA 30% OFF for:
JETBeam – Wuben – NEXTORCH – NITECORE
AND
Lumintop Turboglow Glow Gasket For FW3A & Carclo 105XX just $6.99
I was able again to get a GREAT DEAL for my community!
Banggood.com just listed the
Lumintop 2×19.7mm
Self Illuminate Turboglow Glow Gasket
(Most Triple Optic Light Flashlight)
SPECIFICATIONS
Brand: LUMINTOP
Material: TurboGlow (Best now)
Color: Green, Yellow, Lava, Purple (Other colors out of stock now)
Fit: Carclo 105xx Optic. (10507/10508/10509/10510/10511) triple leds
Fit for most Triple optics lights: TLF/BLF FW3A, barrel,hanko,boss,okluma,reylight.
Note: These are NOT 3D printed and will NOT melt warp chip crack or deform inside the head of your light
to start banggood sells them for $10.90 instead of $13.95
M4DM4X.com fans & friends get it for US$ 6.99 !!
just use my code: MGLOW and my LINK
(only in July!)
one more thing:
share my pages and let your friends know where to get the best deals ;)
use my links to generate traffic even when you do not buy! (that results in better discounts!)
subscribe to my youtube channel and facebook page
mailcall!
Lumintop FW3C + mounting Turboglow Gasket and Button
Hello my dear friend!
Today a beauty arrived! So i had to show you!
You can get your FW3A/C here:
https://m4dm4x.com/fw3c-and-fw3a-sst20-4000k-available-2/
FW3C copper (nichia/SST20/XP-L HI) + FREE holster = $60.90
veröffentlicht am 24. July 2019 in flashlights von m4d m4x
Banggood listed the copper version of the hot selling FW3A with 3 LED versions available and adds a FREE Holster (limited supply!)
Use this link and take care the gift is checked
– then go to the cart and use my code to get it for US$ 60.90!
(ask me or just look in my deals list)
I got a bunch of deals for the new listed Trustfire flashlights.
just click the link or picture to get detailed info at the shop!
Trustfire DF30
2350lm Rechargeable Dive Flashlight
Underwater Diving Photo Video Flashlight
My CODE: MDF30 – your price: $54.95
Trustfire DF70
XPH70 3200lm Neutral White
Underwater Diving Light 26650 Flashlight
my CODE: MDF70 your price: 45.90
Trustfire T70
XHP35 HI 2300lm Lumen
18650 Outdoor Waterproof Hunting Flashlight
my CODE: MT70 your price: 46.90
TrustFire E3R
1000LM USB Rechargeable EDC Flashlight Waterproof 18650 Flashlight
my CODE: ME3R your price: 31.99
Trustfire T3
1000lm Waterproof EDC Flashlight 18650 Tactical Flashlight Mini Torch
my CODE: MT3 your price: 22.90
SKILHUNT M150 750LM AA/LiIon – new deal launched
veröffentlicht am 25. July 2019 in flashlights von m4d m4x
Have you been looking for a AA size flashlight with multi chemisty support, a Cree XP-L LED pushing up to 750 Lumens and dual UserInterface
+ magnetic charging (14500 only) and tail?
So I just added this to my deals list:
SKILHUNT M150
750LM AA Rechargeable EDC
Mini LED Keychain Light
Features
1.Super bright & latest XP-L2 LED, Max 750 lumens. High-Performance, High-Efficiency and energy conservation.
2.New U.D.O.C Reflector. Increased reflectivity over 10%., Efficiency reflection, perfect beamshot, excellent structure and temperature resistance.
3.Built-in magnetic charging system, fast charge and convenient.
4.Rugged indestructible aluminum body with anti-scratching type III hard anodization
5.Multi-level dissipating heat designand new copper starboard, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
6.Side switch button to transferring mode user-friendly interface to adjust output.
7.Two mode groups to meet different use habits, suitable for different environment.
8.Wide input range provides more choices of batteries. High efficiency driver circuit, no visible flash in any mode.
9.Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
10.Intelligent temperature control technology for flashlight stable and safe use.
11.Reverse polarity protection, to protect from improper battery installation.
12.When turn off, hold press button to activate lockout function. Avoid light turn on by unexpected.
13.When light lockout, location indicator will flash, easy get the light in dark.
14.Magnetic tail, can be used in many special occasions, use as candlelight, etc.
Package Included:
1 x SKILHUNT M150 EDC Flashlight
1 x User manual
1 x Spare O-rings
1 x Lanyard
1 x Clip
1 x Magnetic Charging Cable
SKILHUNT M150 can’t see it on your list yet, maybe its just me?
please reload the list - my browser hung...
Q: Skilhunt M150 XP-L2, no mention of flux bin… Without this, can’t figure out tint, and where in each category. According to CREE, there’s CRI MIN 70, 80, 90, and CCT: WW (2700 - 3500K), NW (4000 - 4500), and CW (5000 - 8300). Spec sheet shows flux bins of V2 ~ V6, and U5, U6.
If I order from this link, can i specify carlco optic and glass lens or is that only ordering elsewhere….
