Test/review of Samsung INR18650-36G 3350mAh (Purple)
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 17 hours ago
DSC_3734
Official specifications:
  • Brand: Samsung SDI
  • Model: INR18650-36G
  • Size: 18650
  • Positive: Flat
  • Type: Rechargeable Lithium Ion Battery
  • Protected: No
  • Nominal Voltage: 3.6V
  • Nominal Capacity: 3350mAh
  • Continuous Discharge Rate (CDR): 8A
  • Approximate Dimensions: 18mm x 65mm
  • Approximate Weight: 48g
Samsung%20INR18650-36G%203350mAh%20(Purple)-info
This is a high capacity 18650 cell from Samsung.
DSC_3732 DSC_3733
DSC_3735 DSC_3736
DSC_3738
DSC_3759
Samsung%20INR18650-36G%203350mAh%20(Purple)-Capacity
The two cells are well matches, but the battery do not like high current discharge, it gets rather hot.
Samsung%20INR18650-36G%203350mAh%20(Purple)-Temp-7.0
Samsung%20INR18650-36G%203350mAh%20(Purple)-Temp-10.0
Samsung%20INR18650-36G%203350mAh%20(Purple)-Temp-15.0
Samsung%20INR18650-36G%203350mAh%20(Purple)-CapacityTimeHours
Samsung%20INR18650-36G%203350mAh%20(Purple)-Energy
Samsung%20INR18650-36G%203350mAh%20(Purple)-PowerLoadTime
Samsung%20INR18650-36G%203350mAh%20(Purple)-TripCurrent
Samsung%20INR18650-36G%203350mAh%20(Purple)-Charge
Samsung%20INR18650-36G%203350mAh%20%28Purple%29%20frz-Disc-1.0A-2.8V
I gave this battery a discharge in the freezer, at 1A it has about 2600mAh at -20°C
Samsung%20INR18650-36G%203350mAh%20%28Purple%29-Pulse-1.0A-30-30-2.8V-IR
Conclusion
This is good cell with lots of capacity for a 18650 cell, but it is not for high current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 2 days 22 hours ago
Thanks HKJ!
Dlux
Last seen: 8 hours 40 min ago
Thanks HKJ.
Battery is good, but it is a bit weird that is not any better than 35E
HydrAxx
HydrAxx's picture
Last seen: 3 weeks 3 days ago
Dlux wrote:
Thanks HKJ.
It’s quite normal, this batch of their cells(“2H24”) is a pre-production batch, this model is already under development.
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
Dlux
Oh! It is that, I didn’t know about that detail.
ggf31416
Last seen: 1 day 5 hours ago
The model is sold in several places like a 3600mAh battery since over a year ago, several persons that tested it expecting 3600mah were quite disappointed.
Barkuti
Barkuti's picture
Last seen: 1 hour 46 min ago
HydrAxx wrote:
Dlux wrote:
Thanks HKJ.
It's quite normal, this batch of their cells("2H24") is a pre-production batch, this model is already under development.
Thanks for pinpointing.
So this test is far from an accurate reflection of 36G performance. I also do not see any discharge performance improvement versus 35E, when it should.
Remembers me of this old test station's Samsung 25R (green) review. Actual Samsung 25R performance is quite a bit better than that. See Vapcell INR18650 2500mAh (Purple) 2018 and Ampsplus INR18650 2500mAh (Black), for example.
Smile
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
HydrAxx
HydrAxx's picture
Barkuti wrote:
HydrAxx wrote:
Dlux wrote:
Thanks HKJ.
Remembers me of this old test station’s Samsung 25R (green) review. Actual Samsung 25R performance is quite a bit better than that. See Vapcell INR18650 2500mAh (Purple) 2018 and Ampsplus INR18650 2500mAh (Black), for example.
Smile
And at the same time, I did not have much difficulty in deducing that it was preproduction cells because if you do research on the “36G” yourself, you will notice that only cells from the batch “2H24” are available for sale, batch that has more than two years now, and I also have asked to various suppliers on the net (oye, vbatty, lozd, …) and it all have this same batch “2H24” in stock only, then there are months too I have also touched a few words to Mooch who confirmed me having seen only this batch “2H24” available, all this proves that they are only samples of cells for testing, not the final model.
ggf31416
I wonder what Samsung has to gain by distributing preproduction samples that are known to be inferior, without a strong confidentiality agreement to prevent them from leaking into the grey market.
