Nah it will be fine! My Littokala cells are just as high drain i think. So far no one has killed a SST40 by over amperage unless it was on the test bench. A bunch of us have killed many by trying to dedome them or even slicing the domes far more dangerous.
I’ve been looking into them myself, probably from Cutter. Shame about the cold white on AE though. Planning on converting S11 to eswitch, just need to find appropriate driver….
Hello guys, I am new to this forum. I am into flashlights for some time, so I decided to join this forum to learn something new, and to share my experiences with you…
Speaking of astrolux ft03,I have a question. I bought ft03 with sst40 and decided to dedome it using slicing method. I am not quite satisfied, I liked it more with the dome on. I want to reflow new led. I am in dilemma between sst40 and xhp50.2 . What do you suggest based on your experiences with these leds in this flashlight ?? Thanks in advance
I got the xhp50 yesterday. It rocks. I can not believe the output and the throw.
Better throw than the Convoy L6 or the S70S
More PERCEIVED light than the Q8 or SP36
but it doesnt hold up heat very well or ? atleast the l6 i can run turbo almost nonstop and its not that heavy when i touch the head… i think the ft03 is better have the sst40 version and u get better throw and less heat.
I see HSP and that’s what I think sorry, getting carried away.
XHP70 and 70.2 definitely exist, and they’d physically fit in the FT03, but the issue is that I believe they’re mostly 12v. There’s apparently 6v variants, though. Compared to the 50.2, it’s the same kind of “wall-of-light” profile, just bigger.
