Just noticed this. This is a BLF Q8 running Anduril 02-06-2019 in “OFF”mode, aux off.
Looks like it’s powering the MCU down and up again?
My Q8, and D4S’s do this, my D4’s are steady @ 21yAmps
That’s odd. The speed looks way too slow, unless the DMM is sampling infrequently.
It should cycle between ~5 and ~30 uA about 8 times per second.
This happens on devices with the “sleep ticks” feature enabled, because it leaves the WDT enabled during sleep so it can wake up and change the aux LED state, like for the “blinking” mode. The exact cycling speed is defined by STANDBY_TICK_SPEED.
If there’s no aux LED though, or if you compile without TICK_DURING_STANDBY, the power use should be lower and steady, as you described on the D4.
TK…could you please share some hints on when can we expect 1634 sources?
It’s hard to say for sure. It would have been out by now, but people keep asking me to help them clone Emisar products, so I keep pushing back the release date. I’m not in the business of helping people undercut my clients.
I see, thanks for clarificaiton.
I suppose that’s the problem with open source.
Personally, I prefer the design and execution of Hank’s lights and Anduril is icing on the cake. I will always choose his lights compared to the clones. I would hazard a guess that a lot of other flashaholics would too.
Not sure if this is the correct thread to ask but… I have an Astrolux C8 with a bleeder resistor on the driver and a lit tailcap. Everything worked well but the turbo step down was too quick so I changed TURBO_TIMEOUT to 255 in the A6 firmware (blf-a6.c) and flashed it to my C8. I didn’t specify fuse values when flashing. Upon testing I noticed I couldn’t step backwards anymore. Is this due to a core timings change somewhere in the firmware? Should I play around with the resistors again to get the modes working properly? If it helps, I bought the C8 new from BG one year ago.
Sounds about right, the fuse settings. Had the same issue after flashing my BLF A6. The timing was way off. After reflashing it with the correct fuse values, it worked correctly again
Doesn’t flashing without specifying the fuse values leave them unchanged? Or are you saying I need new fuse values for the (presumably) newer firmware?
Fuse values, are based on what type of MCU you are flashing. ATtiny13, 25, 85 etc.
It probably needs different values for the OTC calibration. The CAP_SHORT / CAP_MED values might not match the hardware.
Specifically, it may be a good idea to use the blf-a6
branch of the code instead of trunk
, because it’s what the light probably shipped with. The copy in trunk has had updates and the calibration is set back to a default which I think matches MtnElectronics’ drivers instead of Banggood’s drivers.
Looking at it now, the blf-a6 branch uses values of 245 and 180, while the trunk branch uses 190 and 94. So that may be what you’re running into.
Banggood’s drivers don’t really have the standby drain configured very well to begin with, and the lighted tailcap makes it worse. Here’s what I measured a few years ago. The blue line is ideal, and is what trunk uses by default. The red line is what Banggood’s drivers do. And when you add a lighted tailcap, it follows an even higher line.
Thanks TK, very helpful and informative post as usual. I’ll check it out on the weekend.
Update: worked like a charm!
I just wanted to post a suggestion for improvement.
When clicking 4 times to exit lockout, it would be nice the if the behavior were:
4-clicks, the light turns on to the last memorized mode
click, click, click, hold, the light turns on to moonlight and starts ramping up
5-clicks, the light turns on to ramp ceiling
click, click, click, click, hold, the light turns on to ramp ceiling and starts ramping down
etc.
Essentially, the fourth click should act as if the light were already out of lockout. This makes sense since if you’re taking the light out of lockout, the next thing you’re going to do is probably turn it on.
I’ve considered doing something like this… making it so anything which exits an “off” or “lockout” mode will also turn the light on. That would mean 4 clicks to exit lockout would go to the regular ramp mode instead of “off” mode. And it might also mean 6 clicks to enter muggle mode would turn the light on.
However, I have no plans to do the other changes mentioned:
click, click, click, click, hold, the light turns on to ramp ceiling and starts ramping downetc.
Basically, it sounds like the suggestion is: Reduce the “exit lockout” mapping from 4 clicks to 3 clicks, and force the button timing to reset after the 3rd click so it will start counting from 0 again. This would mean 5 clicks to access the ceiling, 6 clicks for battcheck, 7 clicks to go immediately back to lockout mode, etc.
But I intend to keep 5, 6, 7, and other clicks the same as they are now — momentary moon without unlocking the light. The most likely changes are:
- Maybe remap 3-click aux LED controls to 7 clicks, to improve consistency between “off” and lockout modes.
- Maybe remap 4-click “exit lockout” so it goes to an “on” state instead of “off”.
Ah I didn’t realize you are able to adjust aux LEDs in lockout. That complicates things somewhat.
Anyways what you are describing sounds like what I was suggesting.
Both sound sensible :+1:
A thought just struck me, and I have to put this out there…
Imagine a website that can build a custom anduril.hex file for you
Imagine a GUI, with some simple drop down menus and boxes to tick.
Select host, select emitter. Select or deselect what extras you want.
Perhaps an advanced menu where you could rearrange what 3 clicks, 4 clicks does, etc.
And then boom, it spits out a freshly assembled .hex
I would wish that in the ramp config of the stepped ramping there was a forth option to adjust the speed of the ramp. I would like it to be a bit faster.
I would also like a way to adjust the button release timeout from a menu for the light to turn off way faster. Like with computer mouse, I prefer quite fast double click, with anduril I tend to activate turbo while I don’t need it.
I kind of think a cool option would be to adjust the turbo level in the software, rather than having to flash a lower turbo version. I think it’d be useful to be able to lower the turbo level to the same as max ramp, meaning double click from off OR on would go to max regulated mode. Basically disabling the FET channel. For the FW3A, the light is really too small to sustain turbo for more than a few seconds anyway, so the option to disable the fet altogether would be interesting. Sort of a better muggle mode, since the FET channel is really what muggles need protecting from.
ToyKeeper, one thing that doesn’t feel right for me with anduril both in stepped and stepless ramping but particularly in stepless ramping is when I’m ramping up and stop too soon (“a tad more light should be just fine”), there is no way to immediately go a bit up.
When inside the window delay, 1H goes down but 1C + 1H also goes down.
Would it be possible to change this ?
I know that I would prefer 1H to always go up and 1C + 1H to always go down because it is how it works outside of the window delay, but to not confuse people who got used to how 1H actually works, would it be possible to have 1C + 1H to go up immediately ?
