Hard to source I guess?
Kaidomain used to sell them if I’m not wrong.
Yeah, good color bins are really hard to source, and are in very high demand.
Pretty old story for the good stuff to be hard to @#$%. There's really no reason for it to be that way other than @#$%. I mean, would that be the same way if people were overall wiser, more knowledgeable and such? Certainly not.
To be honest, do you (plural) really think led developers/manufacturers cannot choose to change the phosphor recipe and base pump frequency to obtain a spot on planckian locus spectral power distribution from led emitters? The answer is yes, some companies are already doing it. I also believe obtaining affordably priced spot on or below planckian locus emitters is accessible, but guess what? More red and less green means less lemons, which means lower flux bin and lower efficiency greenficiency. In my opinion it surely pays off thanks to saturation and just because it simply looks better.
Today i have received my 2nd gen springs and FD2 LEDs.
Everything in perfect conditions.
Great work BSM!
OK guys, I received a notification that I got the springs.
Once I come home, I’ll take pics and physical measurements to make sure everything is OK.
Indeed. Still looking forward to seeing mine arrive in the US.
No hurry though. I look forward to hearing from others how theirs look while I wait.
@iamlucky13, they are very shiny, a real piece of jewelry.
To see how they perform i am going to need some time, as i am a bit busy now.
I was thinking mainly of how the SST-20’s I ordered look, but true, the springs, too. Some very shiny pictures were shared upthread.
I’m not sure yet what my first project will be with the springs - I already have bypasses on some lights, but I knew I’d better have some good springs on hand for future projects.
Say, iamlucky13, why did you only order springs?
I thought people here mostly wanted the LEDs, no?
Uh oh… a joke, I hope?
I guess I will find out when the package arrives whether it has both springs and SST-20’s.
Did a quick preliminary test on them.
1. The overall package was heavier than usual. Must be all that copper goodness.
2. The spring deformation is about what expected: barely any for the large spring, the usual stuff for the small spring.
3. T H I C C.
No pics or tests on them for now.
What does the usual stuff for the small spring mean?
T H I C C = To be Honest I Can't Complain?
Oh right! the LEDs.
I have never used a high CRI nor NW one before, so better someone with more experience describe them.
LEDs arrived today! Into my FW3A they go…
What can I say? They’re awesome! Not rosy on low modes, but 100% neutral. Way better than the nasty green FB4. On turbo it does get rosy.
(I know the wires are the wrong way; I mistakenly reflowed the emitters in reverse)
More importantly get that solder paste and solder balls off there
Yeah.
Because if something bad happens, then shorts could be possible.
I got my LEDs today. I had two MCPCBs laying around. One brand new, and one was used before.
The LED I reflowed on the new MCPCB is fine, but the one on the used MCPCB didn’t work. I tried reflowing it a few more times. I used a copper braid to clean as much solder as possible from the old MCPCB and applied new solder paste. Still nothing. I tried a second LED and no dice. Third, same.
The odds I have three bad LEDs are pretty slim, so logic tells me the MCPCB has to be the problem, even though checking continuity with a multimeter works fine.
I can’t get the pads on the MCPCB back to being copper colored, no matter how much I tried they are still tinned. They test fine for continuity but I’ve reflowed to this board like 10 times now across three LEDs and it’s not working.
I have some more MCPCBs on the slow rowboat from china, when those arrive hopefully I’ll find out that using a new MCPCB will do the trick.
For now it’s beer time.
The LED I did manage to get reflowed went into my S2+ with a 7135x8 nangj 105c running a customized version of Gchart’s Babka firmware. Still greenish on low, but the higher settings look much better than the one that came in this S2 from Simon.
Excellent Jason.
You’re unlucky that the MCPCB doesn’t work.
I actually tested 1/10 SST-20s to check if every one of them were working, and everything did.
That’s actually why it took me a week to start shipping out the LEDs: additional QA is required, since bad LEDs could spell disaster for me and others.
Could you post some beamshots if possible?
