I took a shot at dropping in on Simon’s store, hoping it’s still in operation. .
I guess it is fair to say, there is hurdle between my location and Simo ‘s store. If I made a graphic showing what the hurdle looks like, you would see a picture that points to the fact, I have no idea where to find his store or who Simon of Flashlights is. Back in October of’ 17, word on the street was he was offering S2+ with the Biscotti interface loaded already, before Bangood.
If you have a url for Simon’s store, and posted it hear, I would owe you even more than I do already.
While this thread is on top again thought I’d just say thanks CRX for taking the time to gather all the BLF cheatsheets in one place, very helpful thread.
A little OT, im sorry, but what is the Firmware for driver with 2 channel output, 1 for main led, and 1 for aux led, clicky switch, thank you very much
Yup, my s2+ has Biscotti driver, now i want to mod it with AUX leds, but i am not sure what firmware support aux led?, anduril supports AUX led, but it’s only for e-switch
you misunderstood me, i’m sorry since English is not my native language, so it’s maybe hard for you to understand me
i have stock convoy s2+, it has 8*amc7135 driver, now i want to have an AUX leds under the TIR len( the tir len is install by me), the problem is the stock driver doesn’t support AUX leds, so right now i’m looking for firmware that support AUX leds. Something like Anduril Firmware, but changing mode through tail switch, not e-switch
the driver will be powered all the time, like E-switch driver. MCU will be in low power state so it won’t consume much energy
Rear clicky drivers like the one in the S2 are designed to be controlled by removing power from the driver since there is no other input. The rear switch connects the battery to the driver.
The way the driver knows if the power has been removed for a second or a day is through an OTF or Off Time Capacitor. This keeps the driver MCU powered up very briefly (a few seconds). This allows it to measure the amount of time it was off.
Since the usual point of Aux Leds is to be On when the main Leds are Off, you would need to keep the rear switch in the On position while the main Leds are somehow turned Off.
This fundamental problem is why you never see Aux Leds on rear clicky lights. I certainly have never seen it.
This is why I asked you if you somehow found a way around this basic problem.
The only solution I can think of is a special UI that includes an “Main Led Off” as part of the brightness cycle. So you would blink the rear switch quickly to cycle through the modes such as: low, med, high, off/standby, low, med, etc…
I don’t know if such a UI exists. I would suggest you ask Toykeeper or Tom E if they have ever heard of such a thing. Also, would you even want a UI like this?
I have a Surefire 6P running a Dr. Jones H17F behind an XP-L2 on a Keeppower 16650 that’s one of my frontline lights. I’m also testing my newest concoction, a 17mm FET driver zener-modded running Guppydrv rev2 powering an XHP50 on two 17500’s in a Surefire M3. I’ve already referred to this page a dozen times. Thanks for putting this up.
I read somewhere that this will delete muggle mode and is what I would like to accomplish, I have some harbor freight flashlights to lend to muggles during camping trips, etc
