Interested
waiting for arrival.cant hardly wait
Did anyone measured the amps draw on this XHP50.2 variant?
Interested
i think i read around somewhere 10-12Amps…
We were estimating it would need to pull 14A-16A to do a real 4300 lumen OTF. Of course, it might actually measure a bit less of both. I don’t know if anyone has measured the 50.2 lumens or amp draw yet. I don’t think I’ve seen any of those reports. Maybe the light is still too new and not many people have recieved them yet.
I got 14.8A with VTC5A for XHP50.2.
Thanks. :+1:
Interested, can I please get the coupon code?
mortuus: A_M_K:Did anyone measured the amps draw on this XHP50.2 variant?
I’m measuring around 14 Amps tailcap current on the FT03 XHP50.2 (using UT210E amp meter and a short piece of copper wire to form a loop around the tail tube).
Unfortunately I don’t have a way of measuring lumens. I have a basic lux meter which I can only measure some ceiling bounce lux measurements…
what is considered normal draw for the SST40 version? mine only draws 7.8 with 80% battery.
Sounds normal.
With a fully charged high drain battery they seem to draw about 8.5A-9.5A. It’s never exact with a FET driver.
Sounds normal.
Thanks.
Hi freeme,
I’m interested in this light. Thanks.
AirBreaker
Using the Sofirn 26650 HD battery I only get 3650 lumens at 30 seconds with the 5700K Tint
Unfortunately I don’t own anything better than a 30Q which performs roughly the same.
How do you measure it?
Purchased, thanks freeme!
Funtastic:Using the Sofirn 26650 HD battery I only get 3650 lumens at 30 seconds with the 5700K Tint
The same way you do with a TA Lumen Tube calibrated with Maukka lights. My lumen tube is within 2 lumens of both calibration lights
JasonWW: Funtastic:Using the Sofirn 26650 HD battery I only get 3650 lumens at 30 seconds with the 5700K Tint
Okay, I can’t keep track of who uses what. (unless it’s in their sig)
Did you bypass the springs? After 30 seconds thats still a good result NW tint should be a little down on output vs the cw.
