M150 Pre-sale, 40% Off, Last Day!
https://www.aliexpress.com/item/4000003741777.html?spm=2114.12010615.8148356.33.1eaf4ee8W9vJfk
Pff.. missed the sale by 2 days.. :|
Bummer..
I also missed it.
Not sure I like the circular mode sequence, which appears to be similar to the Folomov “wave” sequence.
Other than that, it looks good.
I have the Folomov 18650S with the wave sequence - don't like it at all. Only thing I like about the M150 is the 1 Click On/Off.
Thank you very much.
Ordered :)
Happy days!
Personally I don’t like mode sequence L-M-H-T-H-M-L
I prefer normal L-M-H-T-L-M-H-T
Also I don’t like cool white LED
Sorry, no buy for me
Myself, I would rather see a more violent drop from turbo back to low instead of the current wave brightness modes pattern..
I like L-M-H-T-L-M-H-T too.
We changed it because considered that the eyes would adapt to light better.
Anyway, it is already done now. If more customers ask for L-M-H-T-L-M-H-T, then we will change back to L-M-H-T-L-M-H-T.
Please, do change the sequence.
And make the drivers available separately maybe, I've already bought one..
Regards
Myself, I would rather see a more violent drop from turbo back to low instead of the current wave brightness modes pattern…
Good idea! :+1:
And make the drivers available separately maybe, I’ve already bought one…
Regards
Yes, I understand the reasoning behind this change, it's just in actual usage scenarios it's not really practical. Looks good on paper, but in practice I could never get used to this UI and all of my lights that are following this sequence are just sitting nicely in their boxes never to get any actual usage.
In practice it's a longer way to go from medium to low let's say by following this sequence. Med > Hi > Turbo > Hi > Med > Low, instead of Mid > Hi > Turbo > Low for ex.
Also, if you're on Hi, you're getting right back to the same level (Hi) in 2 clicks.. which is not what you'd want.. Same goes for Med - Med > Low > Med.. again, not making any sense, just wasted clicks to get round in place. Not to mention that there's no consistency - you could either be in Med and the sequence would go up or it could go down.. whichever that you won't know when needed. Those are practical flaws in actual usage.
Should the sequence be the usual one, you would always know that from a certain level you've always going to go up a step. That's consistentcy, that's good for an actual usage case scenario.
Regards.
And thank you for taking this change in consideration.
I won’t buy with this wave mode sequence.
Yes, I understand the reasoning behind this change, it’s just in actual usage scenarios it’s not really practical. Looks good on paper, but in practice I could never get used to this UI and all of my lights that are following this sequence are just sitting nicely in their boxes never to get any actual usage.
In practice it’s a longer way to go from medium to low let’s say by following this sequence. Med > Hi > Turbo > Hi > Med > Low, instead of Mid > Hi > Turbo > Low for ex.
Also, if you’re on Hi, you’re getting right back to the same level (Hi) in 2 clicks… which is not what you’d want… Same goes for Med - Med > Low > Med… again, not making any sense, just wasted clicks to get round in place. Not to mention that there’s no consistency - you could either be in Med and the sequence would go up or it could go down… whichever that you won’t know when needed. Those are practical flaws in actual usage.
Should the sequence be the usual one, you would always know that from a certain level you’ve always going to go up a step. That’s consistentcy, that’s good for an actual usage case scenario.
Regards.
Thank you very much for explaining. Understand clearly now. :+1:
Just make a vote, which mode sequence you prefer
You can see the archived poll results on the Wayback Machine: https://web.archive.org/web/20221220093741/https://budgetlightforum.com/t/-/72845
Dozens of violent drop testings—-SKILHUNT M150 AA Flashlight
Wow, that is hard to “beat”
The guy on the scooter is like oh no it’s raining flashlights again, better take my umbrella today.
Wooow, respect. Wish every flashlight was that sturdy.
