I’ll take some pictures when it gets dark here. How do you test bare LEDs? I attempted to test two of them by holding the LED in tweezers and using one of the alligator clips on my helping hands to hold the tweezers, then touching the pads with my multimeter. I couldn’t get it to light up, but it’s a crappy test setup so that’s probably it.
I can’t get photos to represent what my eyes see. Maybe I’ll work on that and post some later.
I’ve attempted many times to reflow 4 of these LEDs to the one MCPCB I have left. The MCPCB checks out perfectly with a multimeter, there’s continuity between the three pads to where it’s supposed to be. I’ve cleaned up the pads countless times and retried and retried.
Solder paste, place LED with notch towards negative like the datasheet says, wait for it to flow, bouncy bouncy LED, tap to eject excess solder. Remove heat, wait for it to cool, check with multimeter, zilch, no light. I keep checking another LED I have with the meter to make sure it’ll light it up and it does. I used Matt’s video as a guide when I did 5 LH351Ds a couple months ago and they all worked without a hitch. My troubleshooting brain says the MCPCB has to be the problem since it’s the common element and it was used once before, however it passes every test I can think of.
After reflowing I’ve checked for shorts and nothing.
This is driving me stupid since it has no reason not to work, yet it still doesn’t. Has anyone had a once used MCPCB just not take a reflow no matter what?
I only opened one strip of 5 LEDs. The other is still wrapped in tape, and I’m going to leave it that way until I get my brand new MCPCBs from the slow boat.
This is making me remember when I tried to reflow on the Astrolux S42 MCPCB at one point.
It just wouldn’t work.
It never did work, until the person I sold it to got the same LEDs working fine…
I really hope it’s not the LEDs that are DOA, as it would cost me a pretty penny to get them replaced, and then I would have to get refunded from the supplier.
I mean, I actually sampled some LEDs, and they worked fine. Crushed them with my foot in their packaging, and all of them worked fine and lit up.
I mean, others have received their LEDs and are working fine, which has me worried a lot.
I tend to get obsessively worked up over stuff due to ADHD. I just need to wait for my new MCPCBs to arrive and try again.
The LEDs didn’t appear to be damaged in shipping. They were wrapped in a metric ton of tape.
I’ve only done 6 working reflows in my life at this point, so I’m still a noob. It’s entirely possible that even though I think I’m doing everything right that I’ve still managed to screw something up.
The datasheet shows the little black dot on the same side as the anode, which for connecting LED’s should be positive.
There’s something to do with basic electronic theory such that anode denotes a positive terminal in some cases and negative in others. I don’t understand it, but several online sources say LED’s should be connected with the anode to positive.
Try swapping your power supply leads to the PCB and see if you get light.
Right, on the top of the LED the dot in the corner is positive. But on the bottom pads the notch in the center pad is the negative (cathode) side. I have one working, and I’ve been trying subsequent reflows just like I did the first one that worked.
Did you try testing each LED by sticking your probes into the solder overflow areas on the sides of the emitter pads instead of the wire connection points?
Actually yea and still nothing. I also tested for continuity between the solder sticking out there and the main wire terminals and it passed. I probed just about everything that I can with the multi meter. I don’t know, maybe one of the pads on the LED just won’t get a good connection on this board, but I have no idea.
I’m trying to rule out dead LEDs since that seems pretty unlikely. Either DOA or maybe I damaged them somehow without knowing.
I need a fresh freaking MCPCB to try since I’m getting tired of screwing around with this one. I have a bunch coming from the Convoy store but the tracking stalled like 12 days ago and I have a feeling the stuff will just show up randomly and the tracking will never update.
I’m done for now. When my new boards show up I’ll try again.
Between these and a defective driver I got from KD I’m not having much luck lately.
So patience is not my strong suit at all. I opened the second strip of 5 LEDs that was still taped to oblivion and reflowed one to the same MCPCB I’ve been reflowing all the others to, and it worked perfectly first try.
After that I went back to holding the bare LEDs in tweezers by the sides, then clamping the tweezers in my helping hands so I can test them directly with my multimeter. I did this before and didn’t get anywhere, this time I tested the last 4 LEDs and 3 work perfectly, one doesn’t do anything.
So at this point after testing them directly I’m sure which ones work and which ones don’t.
Final tally is 5 dead 5 working.
I don’t know if they were factory defects, damaged in shipping, or what. The first strip of 5 I opened had 4 dead ones in a row, this makes me think factory defects since they were all together. The second strip of 5 only had the one bad one.
Still, these are good tint bin SST-20s, so at the price I paid I ended up at about $4.00 for each of the 5 working ones. Normal price for the lesser tint binned ones is often around $3.
Hopefully it’s just me and no one else has issues.
The actual per unit price of these leds is a lot lower than $3 or $4, a lot (and the above comment smells like some bad way to believe). Now imagine you aim to build a lamp with a few dozens of emitters, are you sure you are still wanting to pay $4 a piece? Get real for the love of God. I for sure would not be excusing the screw-up.
If this were a store or online retailer I’d be pissed and looking to return them. But I wouldn’t really expect a return or refund policy from some dude on an internet forum. Honestly I’m pissed but it’s probably just not worth the hassle. Minus the shipping the dead LEDs were $7.50
I’m generally an asshole but I was trying my hand at being nice.
