This is making me remember when I tried to reflow on the Astrolux S42 MCPCB at one point.
It just wouldn’t work.
It never did work, until the person I sold it to got the same LEDs working fine…
I really hope it’s not the LEDs that are DOA, as it would cost me a pretty penny to get them replaced, and then I would have to get refunded from the supplier.
I mean, I actually sampled some LEDs, and they worked fine. Crushed them with my foot in their packaging, and all of them worked fine and lit up.
I mean, others have received their LEDs and are working fine, which has me worried a lot.
I tend to get obsessively worked up over stuff due to ADHD. I just need to wait for my new MCPCBs to arrive and try again.
The LEDs didn’t appear to be damaged in shipping. They were wrapped in a metric ton of tape.
I’ve only done 6 working reflows in my life at this point, so I’m still a noob. It’s entirely possible that even though I think I’m doing everything right that I’ve still managed to screw something up.
The datasheet shows the little black dot on the same side as the anode, which for connecting LED’s should be positive.
There’s something to do with basic electronic theory such that anode denotes a positive terminal in some cases and negative in others. I don’t understand it, but several online sources say LED’s should be connected with the anode to positive.
Try swapping your power supply leads to the PCB and see if you get light.
Right, on the top of the LED the dot in the corner is positive. But on the bottom pads the notch in the center pad is the negative (cathode) side. I have one working, and I’ve been trying subsequent reflows just like I did the first one that worked.
Did you try testing each LED by sticking your probes into the solder overflow areas on the sides of the emitter pads instead of the wire connection points?
Actually yea and still nothing. I also tested for continuity between the solder sticking out there and the main wire terminals and it passed. I probed just about everything that I can with the multi meter. I don’t know, maybe one of the pads on the LED just won’t get a good connection on this board, but I have no idea.
I’m trying to rule out dead LEDs since that seems pretty unlikely. Either DOA or maybe I damaged them somehow without knowing.
I need a fresh freaking MCPCB to try since I’m getting tired of screwing around with this one. I have a bunch coming from the Convoy store but the tracking stalled like 12 days ago and I have a feeling the stuff will just show up randomly and the tracking will never update.
I’m done for now. When my new boards show up I’ll try again.
Between these and a defective driver I got from KD I’m not having much luck lately.
So patience is not my strong suit at all. I opened the second strip of 5 LEDs that was still taped to oblivion and reflowed one to the same MCPCB I’ve been reflowing all the others to, and it worked perfectly first try.
After that I went back to holding the bare LEDs in tweezers by the sides, then clamping the tweezers in my helping hands so I can test them directly with my multimeter. I did this before and didn’t get anywhere, this time I tested the last 4 LEDs and 3 work perfectly, one doesn’t do anything.
So at this point after testing them directly I’m sure which ones work and which ones don’t.
Final tally is 5 dead 5 working.
I don’t know if they were factory defects, damaged in shipping, or what. The first strip of 5 I opened had 4 dead ones in a row, this makes me think factory defects since they were all together. The second strip of 5 only had the one bad one.
Still, these are good tint bin SST-20s, so at the price I paid I ended up at about $4.00 for each of the 5 working ones. Normal price for the lesser tint binned ones is often around $3.
Hopefully it’s just me and no one else has issues.
The actual per unit price of these leds is a lot lower than $3 or $4, a lot (and the above comment smells like some bad way to believe). Now imagine you aim to build a lamp with a few dozens of emitters, are you sure you are still wanting to pay $4 a piece? Get real for the love of God. I for sure would not be excusing the screw-up.
If this were a store or online retailer I’d be pissed and looking to return them. But I wouldn’t really expect a return or refund policy from some dude on an internet forum. Honestly I’m pissed but it’s probably just not worth the hassle. Minus the shipping the dead LEDs were $7.50
I’m generally an asshole but I was trying my hand at being nice.
@jasontheguitarist, don’t worry. When you receive your MCPCBs, test out your dead LEDs, and see if they are really dead.
If they are, I’ll talk to the distributor, and refund your 7,50$US.
This is worrying me, as others that only ordered LEDs last GB didn’t have any problems at all using the same shipping methods, and I shipped around 900 LEDs.
I’ll try to make sure everybody is as happy as possible.
