AceBeam TK16 Cu 3x Osram LED -, short introduction, first impressions & a few beamshots
Where was this light purchased? I have not seen the Osram option at any of the distributors.
Tail e-switch using nested tubes… that looks familiar.
To be technical, Acebeam has done that before, but only for something that felt and behaved much like a mechanical switch. I’m glad to see this approach taking off, and I’m looking forward to the SST-20 version of this.
Thanks Mascaratum.
I’m sorry that I won’t be a really big help to your question about the driver.
I guess its possible to change, but I can’t tell you the exactly size, because its covered by some sort of protective cap.
It could be 15mm or even 17mm. :person_facepalming: :innocent:
I ordered the light at mid of April for a “special start-up offer” of 62,21 € / 69,90 $ shipped from “Klarus red-listed”
There is no Osram KW1.1TG LED. They either mangled the name or just fake it.
nice review… looks like a olight baton on steroids! I have a questions does the light turn off all of a sudden or does it get dimmer before shutdown ? i know my batons i hate when they suddenly just turn off because battery is drained… no warning before really :confused:
what is there to say about osram leds in a light like this with triple optics, whats the advantage with that over sst20 ?
The White Flat is considerably more throwy than the SST-20, which itself is more throwy than the XP-L HI .
The TK16 starts flickering in time margin shorter intervals for low battery voltage warning.
This light is so beautiful. For a slightly larger size, it could have accommodated 18350, but at least we now have some really good 16340 from Vapcell. I’m waiting for a group buy from Martin or Freeme. :smiley:
Me Too!
Here are some beam comparison pictures, originally posted What you got today - #9928 by g_damian
Three different LEDs (Nichia 5000K, Osram 6500K, Samsung 4000K) under carclo 10507 (different WB):
With white flat 2mm2 in BLF A6 OP reflector:
TK16 alone (in real life artifacts are not so visible):
Sweet! Thanks for showing it to us :wink:
I assume that many of those artifacts would be lost under a 10511 optic!
I’ve been thinking about which to get , the Osram or the SST20. One throws, another floods; one is cool, another maybe too warm.
How hot does it get on Turbo?
Thanks in advance!
How do you switch back to ECO mode? 10x switch click also?
Anyone know if these are Carclo optics?
Yes
Thank you.
Quick question.
I just received this light in 4000k sst20. In moonlight mode only 2 emitter are lit. In other modes all three are fine.
Is dit normal behavior maybe?
Probably just different forward voltage, but I never had this in dozens of other triples and quads.
All three of them light on my alu 4000k SST-20, moonlight. I don’t think it’s normal behavior.
I have the Osram version and all 3 emitters light on every mode too. That may be some problem on the contacts, solder, or even driver.
Geuzzz, did you get it from Acebeam? I guess their warranty covers that, it may worth talking to them!
Hope you can solve it :wink:
Thanks for checking guys. Bought it at NKON, going to talk to them. Will give an update.
My TK16 works well on all modes, on low all emitetrs are lit.
