SPECIFICATIONS
Brand: LUMINTOP
Material: TurboGlow (Best now)
Color: Green, Yellow, Lava, Purple (Other colors out of stock now)
Fit: Carclo 105xx Optic. (10507/10508/10509/10510/10511) triple leds
Fit for most Triple optics lights: TLF/BLF FW3A, barrel,hanko,boss,okluma,reylight.
Note: These are NOT 3D printed and will NOT melt warp chip crack or deform inside the head of your light
to start banggood sells them for $10.90 instead of $13.95
M4DM4X.com fans & friends get it for US$ 6.99 !! just use my code: MGLOW and my LINK (only in July!)
Have you been looking for a AA size flashlight with multi chemisty support, a Cree XP-L LED pushing up to 750 Lumens and dual UserInterface
+ magnetic charging (14500 only) and tail?
1.Super bright & latest XP-L2 LED, Max 750 lumens. High-Performance, High-Efficiency and energy conservation.
2.New U.D.O.C Reflector. Increased reflectivity over 10%., Efficiency reflection, perfect beamshot, excellent structure and temperature resistance.
3.Built-in magnetic charging system, fast charge and convenient.
4.Rugged indestructible aluminum body with anti-scratching type III hard anodization
5.Multi-level dissipating heat designand new copper starboard, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
6.Side switch button to transferring mode user-friendly interface to adjust output.
7.Two mode groups to meet different use habits, suitable for different environment.
8.Wide input range provides more choices of batteries. High efficiency driver circuit, no visible flash in any mode.
9.Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
10.Intelligent temperature control technology for flashlight stable and safe use.
11.Reverse polarity protection, to protect from improper battery installation.
12.When turn off, hold press button to activate lockout function. Avoid light turn on by unexpected.
13.When light lockout, location indicator will flash, easy get the light in dark.
14.Magnetic tail, can be used in many special occasions, use as candlelight, etc.
Package Included:
1 x SKILHUNT M150 EDC Flashlight
1 x User manual
1 x Spare O-rings
1 x Lanyard
1 x Clip
1 x Magnetic Charging Cable
Q: Skilhunt M150 XP-L2, no mention of flux bin… Without this, can’t figure out tint, and where in each category. According to CREE, there’s CRI MIN 70, 80, 90, and CCT: WW (2700 - 3500K), NW (4000 - 4500), and CW (5000 - 8300). Spec sheet shows flux bins of V2 ~ V6, and U5, U6.
banggood just added a new flashligfht today and ther is already a deal in my list for members
(please follow the links below to the shop for setailed information)
That tank 007 usb10 doesn’t have a internal battery am I right? It just runs off an external battery right? So usb rechargeable is very misleading I think.
