If you don’t mind losing the key/lanyard ring, you can cut off the nub that holds it to the back of the light, or put a small ring magnet around it, to get tail standing capability. I don’t know of any way to add modes to the driver. But you could change it to a linear/FET driver and use 10440, I guess.
If you don’t want to keep it, I’ll give you $5 for it! :innocent:
Has anyone here modded their i3e EOS in copper with a warmer emitter?
Curious S/N. Mine is G04113006, and I got it about 3 years ago. Mine is slightly cooler than neutral white, but thankfully not much blue in it. Hint of green. Was thinking if I could get the head apart, I’d slip in some minus-green filter in it.
Nice. I got a message from DHL. The package is lost. Olight is not answering mails and nowbody is answering the phone when i call the provided phone number.
They have maybe build really nice lights but their support sucks!
Who’s gonna be the first to put an OSRAM “White Flat” into this little light? MascaratumB showed in THIS post that the “White Flat” does well in TIR. Although, he used a Carclo 10507 Triple, and this one has a single emitter TIR. I think it will make a nice little keychain “thrower”!
A very ambitious and skilled person (maybe CRX?) could de-dome a XHP-50, and carve their own quad “reflector” out of a bit of aluminum with a Dremel tool, I guess.
