I’m interested in this HQ Progkey, but when I inquired in the website, I didn’t get a response.
I’m wondering if they ship to my country, and how much might be the shipping cost.
Check these out. I actually had this exact idea for edge mounting the connector a month ago and even ordered parts to build one. Now a more intense Google search shows the exact idea already exists.
Alternative image:
https://www.tindie.com/products/pnoxi/avr-isp-pogo-pin-adapter-2x5-idc2x3-pogo-127mm/
Thank you ordered a couple.
Oh, ok. What pitch did you order?
My link was to the 2.54mm pitch version just for a visual.
I updated my link to the 1.27mm pitch version in-case anyone else orders from it.
One of each thank you.
I missed it if it is in this thread, but how possible is it to attach the pogo pins with a soldering iron? I don’t have a “reflow station” so to speak, so I have been doing most of my soldering with an iron and have been reflowing my emitters with a torch. I am waiting on OSH Park right now, and have been thinking about how difficult it might be to get 6-8 pins soldered on to this tiny board.
Am I right to worry or is it easier than it looks?
Any tips?
I was planning to reflow one side on the stove top then maybe try to kapton tape it down and do the other side. If that doesn’t work i’ll probably try an iron on the 2nd side to get it aligned properly. not sure.
I may try to use my lead free solder on the first side then use leaded solder on the flip side to help keep side #1 in place.
That sounds reasonable. Thank you for the tips!
Maybe you could solder both sides at once with the edge of one of these? Maybe two at a time so each unit acts like a spacer for the other side.
Excellent!
Sweet f0xx
Hi, I need a pogo adapter to flash d4v2’s. Who can I ask to place an order?
Hank from Emisar will sell them soon. These are just parts you have to assemble.
Ahh ok. So just defer to first page to find the source for all the parts?
That’s one option. If you order from Oshpark be sure to get the 2oz board. Pins can be found on Amazon too.
Awesome, thank you.
Hi. I ordered today from OSHPARK these HQ ProgKey but after I read last post I realized I made a mistake in the order. I ordered 1.6mm version. If any of you has assembled this board, can you tell me if this will be a problem if I can used with bent of pogo pins?
So I put it together and got it working. I nuked one with too much heat trying to re-flow on the stove (it might be salvageable but I doubt it).
What I ended up doing:
edit:
Added a few pics of the pin soldering, i’m sure someone can come up with better ways but it’s what I did…
lead free reflow on stove, kapton taping those in place
lightly tin other side with leaded solder, flux paste on pins to hold them while doing hot air
Thanks contactcr!
This will prove helpful when I finally get my key pcbs. I just got some beautiful ones today in the wrong thickness (due to my thickness)… I think the correct ones have been sent to fab, so it will be soon.
Just got my Oshpark boards and soldered everything. Thank you contactcr. Your tips were invaluable.
