Thanks for the reply, Simon. Soon, I will do it!
Ooooohhhh XHP35 HI!
Simon, looks like the new WishList is open
How about L6 host?
Simon please when will be available L21A with xhp35?
Simon,
There are 6500K and 4000K options to choose from, but the product description says 6500K D2-1A and 5000K B4-40E. I Found D2-1A that’s on the BBL, but can’t find B4-40E? Maybe someone can indicate to me where this emitter sits on the BBL??
Simon,
Should be 4000K B4-40E.
KevinZA1988:Simon,
Yeah, I just pointed that out to Simon so he can correct it. My concern is the B4-40E. It doesn’t show that code on the BBL binning picture on the data sheet.
Ah whoops
How about L6 host?
i sell L6 host ,too ,i dont want to add link in my store ,
you can order L6 flashlight ,and note ” L6 host” ,then i will adjust the amount
oweban: KevinZA1988:Simon,
Thank you for reminding me, I changed it.
1stein:Simon, looks like the new WishList is open
How about L6 host?
Thanks, PMed
The XHP35 driver, is it for 12V LED’s ?
yes, 12V
Apparently H1 UI updated for the traditional Olight/Thrunite style UI.
Interesting… Can now look into emitter swaps for high CRI. Would suggest a new headband with over-head strap, though.
Interesting, where do you see this?
https://old.reddit.com/r/flashlight/comments/ck5r0y/convoy_h1_new_updated_ui/
https://old.reddit.com/r/flashlight/comments/cglpzx/nld_convoy_h1/evh3bxo/
Got a post of mine re: the UI responded to, so hey, if that’s accurate, everyone should know
Hello Simon,
Does the XHP35 HI 4000K B4-40E have 90 CRI?
Hello Simon,
not high CRI
I would suggest XHP70.2 with 21700 for floody beam profile.
High CRI led is really what a headlamp should be! Now is “Durian” season, picker need to see clearly at night in search of durian. Some time green durian and green grass make searching a lot challenging. we need a good colour contrast and also a good battery which Convoy already have…great! Looking for an upgrade version…
Swap out the MCPCB in the H1 for a 16mm SST20 or LH351D
