I thought about this previously (time delay) for going above the ceiling. Right now you have the ramp ceiling and double-click to turbo. But nothing in between (going up) which can be unfortunate if you set a low ceiling.
Perhaps it would be useful to have a medium delay (idk maybe ~2s ?) to “break through” the ceiling and continue ramping above it?
Or maybe not, I am just thinking out loud.
FWIW, I was able to easily create a PDF file of the FW3A manual by (1) first installing the free version of CutePDF Writer, (2) right-clicking the manual at the above link and selecting Print, and (3) selecting CutePDF Writer as the printer. Then voila, my PDF copy was saved.
Edited: Got a free SaberCatHost file hosting account and uploaded the PDF Anduril manual for anyone that wants to download it. Here it is.
Is Andúril (full version with all strobe modes) available as standard on any single emitter 18650/20700/21700 lights? Love the FW3A, but a light with single emitter is better for my use cases (connecting to light painting tools).
I just read these messages and didn’t know that the FW3A has had their firmwares updated. I still have the first release FW3A and tested the 2-stage lockout — it looks like mine is still the old version without the 2-stage lockout. (Tested the same button sequence on the Emisar D4v2, and noted that it had the 2-stage lockout feature).
This points to a few things: Lumintop does use new firmware on the FW3A when it’s available (unlike on the BLF Q8 and I think Sofirn Q8, even their latest batches apparently still use NarsilM v1.0, instead of NarsilM v1.2)
Compile-time, yes. Runtime, a little bit. You can heat the light up and set the temperature calibration to 1 °C. Then set the limit to the highest value.
I read somewhere that this will delete muggle mode and is what I would like to accomplish, I have some harbor freight flashlights to lend to muggles during camping trips, etc
Untwist tailcap to lockout mechanically. Press and hold button andwhile holding tighten tailcap. Still hold the button for about 3 seconds while the light blinking something. Then when it is ramping up it is done.
That’s because I keep sending new files to Lumintop.
I generally send new files periodically to every manufacturer using Anduril. Some update their drivers, some don’t. I think it mostly depends on how much old stock is waiting to be sold… like, if they still have 3000 drivers with old firmware, they generally won’t update it. But if it’s just a few left, the next batch is usually made with newer firmware.
Hopefully I’m not commenting on this too late and reviving the thread. I just got my first enthusiast light (FW3T) and I’m super impressed with the UI. I do have one question, however. When activating candle mode (click, click, hold) is the default setting for it to go until the user turns it off? If that is correct, then 3 clicks will make it thirty minutes with +30 minutes with each subsequent 3 clicks?
Default of candle is run until you turn it off or go to another mode. 3 clicks while in candle mode and the light will give you an acknowledge blink that adds 30 minutes and it’ll turn off by itself when timer is up. I’m not sure how many you can add, I’ve never tried more than once. ToyKeeper will know that part.
The candle timer can go up to about 255 “pseudo minutes”. The details don’t really matter much, but it uses an internal unit which is a bit longer than a minute… and it can represent something like 4.6 or 4.7 hours before overflowing, so it’ll let the user set a timer up to that long. If the current timer +30m is too long, it’ll refuse to add any more.
Anyway, TL;DR: candle timer can go up to about 4.5 hours.
If the timer isn’t set, it’ll go until the user turns it off or until low-voltage protection sends a warning. In the LVP scenario, it goes to a low steady mode, then proceeds through the usual repeated-step-down and turn-off it would do in a regular ramping mode.
Each time candle mode is started, the timer is reset to “none”. So if you set a timer and then cancel it by turning the light off, it won’t remember or resume next time… it’ll start from zero again.
