SKILHUNT Offers and Flash sales
422 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 30 min 34 sec ago
SKILHUNT wrote:
M150 AA Magnetic rechargeable flashlight
Any news about this flashlight, SKILHUNT??!
SKILHUNT
SKILHUNT's picture
Last seen: 1 day 18 hours ago
Now Release!
https://www.skilhunt.com/product-detail/m150-usb-magnetic-charging-flash...
samyy
Last seen: 3 weeks 14 hours ago
XPL2? Facepalm Bad choice, veeeeery bad… Sick
MascaratumB
SKILHUNT wrote:
Now Release!
Thanks for the link Wink
SKILHUNT
SKILHUNT's picture
80T
80T's picture
Last seen: 1 month 6 days ago
LightObsession
Last seen: 3 months 1 day ago
I also missed it.
Not sure I like the circular mode sequence, which appears to be similar to the Folomov “wave” sequence.
Other than that, it looks good.
80T
80T's picture
LightObsession wrote:
I also missed it. Not sure I like the circular mode sequence, which appears to be similar to the Folomov “wave” sequence. Other than that, it looks good.
I have the Folomov 18650S with the wave sequence - don't like it at all. Only thing I like about the M150 is the 1 Click On/Off.
samyy
40% Off again on AE here
80T
80T's picture
samyy wrote:
40% Off again on AE "here":https://www.aliexpress.com/item/4000003884168.html?spm=2114.search0104.3...
Thank you very much.
Ordered Smile
Happy days!
varbos
Last seen: 1 month 4 weeks ago
Personally I don’t like mode sequence L-M-H-T-H-M-L
I prefer normal L-M-H-T-L-M-H-T
Also I don’t like cool white LED
Sorry, no buy for me
SKILHUNT
SKILHUNT's picture
Dozens of violent drop testings—-SKILHUNT M150 AA Flashlight
https://youtu.be/m9fdKIo85HA
80T
80T's picture
Myself, I would rather see a more violent drop from turbo back to low instead of the current wave brightness modes pattern..
SKILHUNT
SKILHUNT's picture
I like L-M-H-T-L-M-H-T too. Wink
We changed it because considered that the eyes would adapt to light better.
Anyway, it is already done now. If more customers ask for L-M-H-T-L-M-H-T, then we will change back to L-M-H-T-L-M-H-T.
80T
80T's picture
Please, do change the sequence.
And make the drivers available separately maybe, I've already bought one..
Regards
SKILHUNT
SKILHUNT's picture
Good idea! Thumbs Up
SKILHUNT
SKILHUNT's picture
And make the drivers available separately maybe, I’ve already bought one..
Regards
80T
80T's picture
Yes, I understand the reasoning behind this change, it's just in actual usage scenarios it's not really practical. Looks good on paper, but in practice I could never get used to this UI and all of my lights that are following this sequence are just sitting nicely in their boxes never to get any actual usage.
In practice it's a longer way to go from medium to low let's say by following this sequence. Med > Hi > Turbo > Hi > Med > Low, instead of Mid > Hi > Turbo > Low for ex.
Also, if you're on Hi, you're getting right back to the same level (Hi) in 2 clicks.. which is not what you'd want.. Same goes for Med - Med > Low > Med.. again, not making any sense, just wasted clicks to get round in place. Not to mention that there's no consistency - you could either be in Med and the sequence would go up or it could go down.. whichever that you won't know when needed. Those are practical flaws in actual usage.
Should the sequence be the usual one, you would always know that from a certain level you've always going to go up a step. That's consistentcy, that's good for an actual usage case scenario.
Regards.
And thank you for taking this change in consideration.
LightObsession
I won’t buy with this wave mode sequence.
SKILHUNT
SKILHUNT's picture
80T wrote:
Yes, I understand the reasoning behind this change, it’s just in actual usage scenarios it’s not really practical. Looks good on paper, but in practice I could never get used to this UI and all of my lights that are following this sequence are just sitting nicely in their boxes never to get any actual usage.
In practice it’s a longer way to go from medium to low let’s say by following this sequence. Med > Hi > Turbo > Hi > Med > Low, instead of Mid > Hi > Turbo > Low for ex.
Also, if you’re on Hi, you’re getting right back to the same level (Hi) in 2 clicks.. which is not what you’d want.. Same goes for Med – Med > Low > Med.. again, not making any sense, just wasted clicks to get round in place. Not to mention that there’s no consistency – you could either be in Med and the sequence would go up or it could go down.. whichever that you won’t know when needed. Those are practical flaws in actual usage.
Should the sequence be the usual one, you would always know that from a certain level you’ve always going to go up a step. That’s consistentcy, that’s good for an actual usage case scenario.
Regards.
Thank you very much for explaining. Understand clearly now. Thumbs Up
SKILHUNT
SKILHUNT's picture
Just make a vote, which mode sequence you prefer
http://budgetlightforum.com/node/68236
MascaratumB
Wow, that is hard to “beat” Crown
hIKARInoob
hIKARInoob's picture
Last seen: 8 hours 37 min ago
The guy on the scooter is like oh no it’s raining flashlights again, better take my umbrella today.
1stein
1stein's picture
Last seen: 57 min 51 sec ago
Wooow, respect. Wish every flashlight was that sturdy.
SKILHUNT
SKILHUNT's picture
Thanks, we will try our best to do this.
80T
80T's picture
If you're going to make changes to this light, you might also want to have more options for the emitter choice and especially the reflector. Give us the option to have smaller / bigger emitters and OP / SMO reflectors. The XP-L emitter is kinda small, and it goes just fine with this size reflector  but what kills this combo for me it's the OP reflector. The hot-spot will be so smooth than it almost won't be distinguishable from the Corona, it will be an almost complete fade from center to whereabouts the corona would end and even further. Myself, I'd take this light with either the XP-L (not XP-L2 because of the tint shift) or even an XM-L2 or SST-40 and a SMO reflector. Should I ever prefer an OP reflector, I'd take it at least with an XHP35 / XM-L2 / SST-40 size emitter. It would also be a nice choice for whomever prefers more throw, to have an XP-G alternative with the SMO reflector as well.
Regards.
SKILHUNT
SKILHUNT's picture
80T wrote:
If you’re going to make changes to this light, you might also want to have more options for the emitter choice and especially the reflector. Give us the option to have smaller / bigger emitters and OP / SMO reflectors. The XP-L emitter is kinda small, and it goes just fine with this size reflector  but what kills this combo for me it’s the OP reflector. The hot-spot will be so smooth than it almost won’t be distinguishable from the Corona, it will be an almost complete fade from center to whereabouts the corona would end and even further. Myself, I’d take this light with either the XP-L (not XP-L2 because of the tint shift) or even an XM-L2 or SST-40 and a SMO reflector. Should I ever prefer an OP reflector, I’d take it at least with an XHP35 / XM-L2 / SST-40 size emitter. It would also be a nice choice for whomever prefers more throw, to have an XP-G alternative with the SMO reflector as well.
Regards.
More options (with easy change), we would like to offer if confirmed require more than 50pcs.
Ryzbor
Ryzbor's picture
Last seen: 2 weeks 4 days ago
Dear Skilhunt,
If you want to give the buyer choices, the best would be to offer your models in both 4000K (Neutral-Warm) and 5000K (Neutral-White). In this way you’d cover roughly 80% of most people preferences.
Unfortunately the leds you use are not really pretty since they are binned above the BBL = they are greenish = ugly. 4000K 5D/5A and 5000K 3A tint binned Cree leds are famous here for for producing beautiful neutral-rosy light. They are easy to obtain.
*Being known for using nice leds = more profit. *
Keep your flashlights mod friendly, this will allow people who want either true warm, true cool or high-cri light achieve it using one of your models and not by switching to a different brand.
A great example it the H03 which is a popular light for modifications in the flashlight community, mostly because beside it’s good quality it’s relatively easy to open, beside that the head is glued to the body. So please don’t glue shut your flashlights.
Doing this will result in extra people buying your lights just for modding = more profit.
It’s easy to overengineer a flashlight by implementing fanservice solutions like onboard charging which can short-circout, indicator leds which consume lots energy and switching to super-fancy UI’s.
Last but not least: keep the price decent. The H03 costed ~30$ on your Aliexpress store, now it’s 43$. Why?
I’d much prefer to order it directly from you instead of Gearbest but when GB can offer a ~29$ price for it it becomes a easy choice.
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
1stein
1stein's picture
Ryzbor wrote:
Dear Skilhunt,
Truth. Agree witch each Ryzbor’s point.
varbos
Ryzbor wrote:
Dear Skilhunt,
I disagree.
-Tint is fine on my Skilhunt flashlights
-A glued head is better – it will not accidentally unscrew when flashlight is on headband and user twists head to change angle.
-In-built charging is very useful. Especially when it is very compact like H03RC
-Indicator LEDs are very useful.
-Sometimes making things ‘mod friendly’ results in big and bulky flashlight. I don’t want this. H03 is very compact.
Skilhunt makes finished products for consumers who just want flashlight, not DIY kits for modders. From your suggestions it seems you want the company to change to DIY stuff like Convoy. Why? If you want a Convoy, buy a Convoy. Don’t ry to ruin Skilhunt for everyone else.
