i have just received this cell( not from this seller), so far so good, the capacity is in range 3400-3500, and the IR( measured with 4 wires probe) is <23mOhm
i think you should check it, maybe the best high capacity 18650 right now
ps: there are a lot “interesting” cells in China, if only you can buy from there
there is a 3100mah cell and 35mOhm IR that cost lest than $2, and the NCR18650BG i got is only $2
So I overlook it somehow, or I didn’t explain it clearly…
When I hoover my mouse pointer over the link on the left a window pops up with measured values.
That’s great because that’s what I’m looking for.
My request is that those measured values are also in the table so I can sort on them.
You see, I fully trust your tests. Yesterday I was searching for 14500’s that have a max drain of at least 2A.
So I want to sort mAh at 3A, and then I buy the cell with the highest mAh.
That way I just have to click a few times instead of checking all cells one by one.
3A is in the table and you can click on the header to sort it.
You can also select different discharge voltage above the table, it is best to only check one voltage at a time.
I'm here for a small review proposal or suggestion, DIY stuff gizmo. It is not a battery, but I think this thread is the closest related thing to (maybe some other generic or DIY review request thread could be nice).
It is an inexpensive “TC4056A” li-ion charging board with attached adjustable output boost converter. There is no protection circuitry for the battery but they're ;-) easy to find.
The board uses a schottky diode at the output (SS36, by the way), this means it could be possible to set it in parallel with others (but needs very tight output voltage adjustment).
That was maybe a hasty comment. The onboard output circutry is a boost engine, this means at some point it'll stop working due to too low battery voltage.
Mmm, looks like the SX1308/MT3608 will have to wait. :???:
A fellow from the far east who sometimes posts in this forum suggested me the above fake NCR18650B I spoke about is a BAK 18650-34T, with performance probably on par with NCR18650GA. This was sometime ago, but definitively I do not seem to find a way to obtain 18650-34T cells with their OEM wrap directly for sale in AliExpress:
I have a couple sales in my wishlist for what looks to be these cells, with what looks to be a pentagon top clearly distinguishable under small soldering tabs or cables. They are disguised as “green berets”, though.
yeah, it’s 1khz sine IR measurement, i measured the VTC5A with that meter, i got 9.8mOhm
i bought those from 1688.com ( wholesale website from China) so i guess it’s quite hard for HKJ to purchase these cells from there.
PM me the address then (a valid AliExpress' address), so I can submit it to the AliExpress seller I chose to buy from. This is the way I can afford it to be. Thanks.
I see metal shell case power resistors for sale in many places. Looks like the sort of thing but, how does the above and similar meters use them? Do they switch the load with variable PWM duty cycle to keep a constant current or a constant power?
Trying to determine what resistor values would cover a few low voltage li-ion tests.
