Nanjg 105c always on
4 posts / 0 new
YuvalS
YuvalS's picture
Last seen: 4 hours 10 min ago
Hi all,
I am building an Headlamp and having an issue with the Nanjg 105c driver.
After flashing the FW and connecting the battery the LED is always on even for very simple  OCR0B = 0; OCR0A = 0;  FW.
The same FW and driver worked great before but I did some soldering and may destroy something.
Any idea what could go wrong?
Thanks
Yuval
My FW repository
My BLF/OL contest entries: 7th 8th 9th
YuvalS
YuvalS's picture
My guess is that one 7135 is malfunction and always on.
1. Is it possible?
2. Is there a simple way to check all 7135s on board without soldering it out 1 by 1
My FW repository
Henk4U2
Henk4U2's picture
Last seen: 48 min 34 sec ago
Hi Yuval, maybe I am mis-understanding you completely. If so, I apologize.
But there is no switch on the driver board. That is in the tail, or elsewhere in the light.
If you connect the battery, some current will flow. Question is: how much.
Is the light always 100% on? Can you regulate the current by clicking?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
YuvalS
YuvalS's picture
Henk4U2 wrote:
Hi Yuval, maybe I am mis-understanding you completely. If so, I apologize. But there is no switch on the driver board. That is in the tail, or elsewhere in the light. If you connect the battery, some current will flow. Question is: how much. Is the light always 100% on? Can you regulate the current by clicking?
I am connecting momentary switch to pin 2 on pull down mode but it has no affect.
I try to flash a very simple blink FW and also always off FW but no mater what, the LED is always on when I connect a battery.
I don't know if it is 100% or less
My FW repository
