LOL
Lucky you.
LOL
Lucky you.
hahahaha. I’m serious I have the head in a vise. Not budging. About to give up.
Use a big hammer.
I’m ready to use a blowtorch
I’ve never seen a glued retaining ring in these but could be, maybe a little heat?,
Loosen the front bezel a half turn too.
Yeah. The one I have definitely had threadlocker between the head and the battery tube, so wondering if some of that might have seeped towards the retaining ring. I’ve tried clamping down hard on the outside of the body to see if it might just be frozen in place but again, no luck!
Mine had black thermal/potting compound leaked down almost to the battery tube,
I’m going to stop messing with it for now. Hands are completely raw due to the super aggressive knurling.
Use some oil of Olay .
I remember when it used to be Ulay. Marathons, Opal Fruits, Treats.
I have good news and bad news:
good news: I got the retaining ring off
bad news: I sheared the pcb off the bottom of the pill
Use the bin.
You’re supposed to say “make it into a triple”
Make it into a triple.
Yay…No. …
Ouch.
Must have been stuck on there good?
Enough of the triples, plenty of space in there for four emitters.
Make it into a quadruple.
That’s the spirit
Yeah, confirmed threadlocker on the retaining ring. If I align the pcb just right and tighten it down cautiously it turns on for a bit.
You could possibly fix it if you took the rest of the driver out of the potting compound but not confident.
You might want to look at these threads now..
NovaTac 120T Triple Nichia 219C 5000K - H17Fx - 18350 - Tail Clicky.
NovaTac 120P Triple Nichia 219C 4000K 90CRI H17-Fx - 18350 - Tail Clicky.
