Interested, but I’m concerned about how Anduril will be ported for a boost driver, and of course the associated problems with boosting a NiMH/Alkaline.
I see myself using this light normally on 14500, where I would wish to have a max of ~600 lumens. But in case of emergency, it would be nice to also be able to run off of a AA/NiMH, where I wouldn’t want 600-700 lumens anyway to conserve power. I’d be fine with a max of ~100 lumens, which all chemistries should be able to handle.
Interested.
How did Wuben the magic in its E05(-I)? It runs on NiMH the same modes as on 14500, except turbo. Is this a matter of efficiency?
sounds good to me, interested for sure
Would it be possible to limit the power of the flashlight when running on NiMh on the basis of max optimal load for that cell chemistry? Unsure if that would be easier or harder
Interested
This is mandatory.
Only just realised I haven’t explicitly expressed my interest. So… interested!
Very interested if the light comes with a lighted switch or dim indicator light (or is easily modded to have one)
Dual chemistry would be great to see!
Interested if it comes with nimh support and anduril
Interested
Interested
Interested
Interested!
Interested
heck I’m in… I am in the market for an AA edc and had just started looking…. My short list was the Utorch, lumintop tool 2 and sofirn sp10s!!! so this would be great!!! BUT ONLY IF IT CAN RUN ON AA’s too…
Interested even if it only work with 14500.
Interested if it’s aa compatible. Could you somehow make the glass have a built in minus green filter?
interested if it supports alkaline/nimh as well. Not sure why there is a debate about the possibility, the original light does it, as do other lights in this size (Rofis R2). Perhaps adding Anduril and a small board is the challenge? Certainly the lower voltage cells have lower outputs.
Sorry, I only read through 2 or 3 pages of the thread.
Interested
