Potting, beginner to advanced
18 posts / 0 new
QMT93
Last seen: 1 year 6 months ago
Hi,
I don’t know how to pot flashlight, and would love a complete beginner’s course on it (intermediate and advanced welcome): where in the head of the light I can pour epoxy in, compatibility with specific chemicals, drivers, etc. if any.
I’m planning on potting my C8+, hence this thread.
I’m not just looking for potting material option, but rather, a guide of where, and how to pot.
Hope to hear from you soon.
Corvette
this is a great idea, I would love the same input. looked through youtube but found varying degrees of success on there. a guide focused on flashlights would be great.
QMT93
Guys, any thoughts? It’s a bit dark in here.
freeme
freeme's picture
Last seen: 5 hours 7 min ago
Topic reminds me of Pflexpro company. These guys are expert in potting lights.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
QMT93
I’ve never had the chance to try one from them. However, based on the photo, I’d say they pour epoxy even on the driver itself? Is that applied to the entire head of the light?
arek98
Last seen: 8 hours 30 min ago
I used MG 832 epoxy https://www.mgchemicals.com/products/potting-compounds/epoxy-potting-com...
Be aware that whatever you potting you need to seal all gaps to make sure potting compound gets only where you need it.
For example this MG epoxy seems thick but it will get into smallest voids and leak if not properly secured.
Also this one is permanent, hard stuff, impossible to remove without braking whatever was potted.
You may look into some urethane based potting compounds, these are soft and flexible.
Stay away from stuff that is not meant for potting. Some epoxies shrink or expand too much when curing. It may cause electronic components to dislocate and break circuit.
f0xx
f0xx's picture
Last seen: 1 week 23 hours ago
Utilizing the search button, I found several threads already here on BLF.
Here are a few:
http://budgetlightforum.com/node/64010
http://budgetlightforum.com/node/25034
http://budgetlightforum.com/node/59780
Hope this helps
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 day 3 hours ago
My 4000lm XHP-70 light never gets HOT………. as the LED fries?
It will now… Big Smile
KB1428 “Live Life WOT
QMT93
Ah, thanks! I didn’t have the chance to open further links because I was on a cellphone. Will check them out.
QMT93
@KawiBoy1428: I’m sorry I really can’t follow what you’re saying. Can you elaborate?
QMT93
Hi,
Thanks for your input! Is it correct to say that I can pour the potting material directly on the driver, and it still works?
KawiBoy1428
The whole heat sink is filled with Alum-Fast. just drilled tapped holes to mount board and drilled for pass thru leads. Cheap and it works.
I also use MG Chemicals…
This whole head (module) is potted with MG Chemicals thermal potting, driver, copper sink, reflector.
The head can go on different battery tubes I made…
QMT93
That looks awesome! You made those lights?
KawiBoy1428
Mostly…..can’t buy them like that…based on the M3 Combat Lights and 961/962 weapon lights, had some help from a couple friends…
Battery tubes, M3 bezel adapters, modified Surefire tail caps, I had the reflectors custom by Dan Chan HK and copper pills made by Sinner, the original design for the pill/sink Randy Brogden.
Had a spring named after me…… Big Smile
QMT93
They look amazing! I’m drooling.
I realize that all of the dropins are potted. What are the three dots on those potted dropins?
The Lambert spring is actually awesome!
KawiBoy1428
That is where you select your mode groups, with conductive paint, sort of like soldering the stars on Q-Lite driver…..
QMT93
I see. Thanks!
Matjazz
Matjazz's picture
Last seen: 1 month 2 days ago
I’m planning on potting headlamp drivers. I got my self a Electrolube “ER2074RP250G – Epoxy Resin, Thermally Conductive, White, Packet, 250g” that is packed in a single plastic bag with resin and hardener separated. I haven’t tested it yet but a compound in two separate cans seems more convenient.
Which potting compound do you use?
Now I see
