Adhara, thank you for the feedback. I ended up placing an order with Vinh for a 6500k W30vn copy, awaiting receipt of goods, but sounds like I made the right choice. Atleast sheer output speaking. Been following the candlepower forum thread that AmericanDissent is talking about, so strange that copy wouldn’t boost, 1.8 is a tremendous output but I’m sure disappointing when expecting some increase. I know Vinh talked about inconsistent QC with alignment, but for it to not accept the mod at all is confounding. I’ll chime in when it arrives and let you guys know if the problem was isolated to that copy or not. Have a good one all!
Does 228lumen seem low? I know vinh was talking about only getting 300-350 from 6500k. Both are well under the claimed output. How does the HCRI throw? Look good? Do you like it? Any beam shots?
Not a typo. There is a huge tint shift within the hotspot. There is a ULTRA CW hole at the center. Highest point I measure was actually slightly over 20,000K but the point is very small.
I’m waiting for it to get dark to see how it throws.
So you got the W30 high-cri, not the W10 high-cri? Do you think there is a difference between the two regarding the tint (some beamshots of the W10 were linked to a few weeks ago).
He barely dipped it 1-2 inches into water, any IPX-8/7 rated flashlight can do it specially in freshwater like that, what im really looking to, is seeing this flashlight being used in saltwater or at least dipped for enough time and depth in freshwater.
It is not sold as a dive light and specifications are not always correct. I would hesitate to go salt water diving with my expensive W30 and maybe then go through all the fun with Acebeam’s customer service after water ingression at 25 meter.
I tried to order one from Amazon.de,but by mistake I ordered one 4000K and not the 6500k one.Is there a big difference in tint-lux between the two?
I try to cancel my order but the system sucks.
I have neither but I would assume with previous lights that there will be a noticeable difference in tint. And you will get slightly more lux with the 4000k.
Although, if anyone with more knowledge wants to chime in. . . .
I have just received one of them,but as it is noon here in Athens,I wait till the night.
Until then,I tried to the white walls and the ceiling,but I saw that besides the small-intense center beam spot,there is a large orange corona around this,something that I don’t see in the photographs of the reviewer and I don’t like.
Is it OK?
I have finally ordered it as a 6500°K,but I can’t find where it is written this,because I think if they sent me the 4000°K version.
Edit.
I found written on the box,that it is really a 6500°K version.
Looking that it has a 21700 battery inside,I looked at my four chargers,which are,LiitoKala Li- 500,Thrunite MCC-4S, Nitecore SC4,and XTAR VC4,I see that the 21700 is not compatible to any of them.So,I have to put it in a box and use a 18650 instead,or I have to buy a new charger compatible.
What do you suggest please?
Finally,I tried to put a 18650 in,using the cylidrical case,but it is not working,as the battery length is shorter than this of the 21700 one.So,I found a button top 18650,and now it is working.
And the last one.
I took some photos of the beam spot and saw that while I see orange corona with my own eyes,The photos are the same as the reviewer.A little blue one…
