At short distance the light is not collimated at all, so you get that very moderate 500-ish lumen spread out from the very large surface area of the complete lens. The filter will not melt and your S2+ will feel hotter.
I read more posts about how dangerous the beam from this light is, but in the end it is just a low power 500 lumen flashlight, the only special thing about it is that the light rays coming out of the lens are very very parallel.
Does anyone know how powerful the laser is? For it to produce 500 lumens, it has to be packing some serious energy. Strip out the phosphor, and it could make for a wicked laser source.
I guess it is a couple of watts blue laser, very dangerous stuff but widely for sale for as low as under 50 dollar as a source for laser engraving machines. No need to demolish your precious W30 for that. In fact the most special part of these LEP lights is the bit of phosfor that makes the white light and that can handle the concentrated laser power without being destructed.
If you want a very good laser pointer,I put a link for this. https://www.sanwulasers.com/ .
They make very good ,but of course expensive lasers.I have got from them a 5W blue one.Very strong.And dangerous…
[/quote]
I use green lasers for astronomy, I have a 50mw ,27mw & 17mw, they can be dangerous in the wrong hands.
There will never be an “Osram verison” because this light isn’t using an LED, that’s the whole point of it. A white flat zoomie or traditional thrower can be built right now.
I think Matt’s example with the diffuser material shows that isn’t the case. 400-500 lumens from even a floody beam is very bright at night still.
Just received mine in neutral white. It’s a yellow tint in the daytime but looking forward to testing tonight.
I’ll echo the safety precautions here. Even in the daytime a quick ceiling bounce test was “blinding” - this light is extremely powerful and abundant caution should be used when handling.
I think I have the W30 in one hand,and the 5W blue laser in the other.In a state of emergency,I light up the face of the intruder with the W30,and if it is not enough,I light the laser, so he will be blind in a part of a second. :innocent:
I think the real danger with this torch is it will get mis classified by people who do not understand the technology as a Laser pointer, imagine trying to explain to an over zealous law officer that despite this product being referred to as a white laser and also containing a Class 3b or above laser diode it is in fact not a laser at all simply a torch……… I have an idea how its going to go and i suspect its going to suck.
I just had a look at the documentation and its been classified as a Class 2M laser by the manufacturer, In the UK its legal to own any laser even nasty Class 4s, but if you are using it outside and get deemed to have misused it(even if you haven’t) then it comes under some pretty nasty laws with serious penalties
I totally understand that this doesn’t output coherent laser light , it is simply exciting phosphor with one but with that classification it could be tricky to defend.
The trouble is they(the police) are going to see this pencil thin beam quite unlike any normal flashlight they have ever seen , check the manufacturer see Class 2m Laser and arrest you probably then offering you a choice of surrendering it (confiscation) or taking your chances in court , either option kinda sucks.
It really doesn’t help the situation having sellers referring to it as
If a cop stops you, what they see is a flashlight. They know the difference between a laser and a flashlight. A laser can blind a pilot at 15000 feet, the W30 is bright out to 2000ish meters.
I got to play around with the high CRI W30. What a crazy thing.
The spot has some serious rainbow and a green tint in the middle, but it doesn’t really matter at distance. I’d love to see the 4000K low CRI version, since it probably has about 25% more output. I got 324 lumens from this one with an almost full battery at 30 seconds.
Here’s the CRI data integrated. It’s not high CRI as we would normally define it, but for a LEP it’s quite impressive. Measuring the spot reliably would need a lot more distance than I have available indoors. Even a small movement causes the results to vary too much for anything meaningful. Same goes for throw measurements.
