loneoceans say for 7w light output he driving with about 21w power in! it seem like this driver can do 50w power, so this is why i suggest to make a very powerful buck driver for flashlight using same design!
Flashlight driver doesnāt sit on a thick piece of copper though and it wont fit on 17mm. Iām sure there is some that can be adapted to flashlights though
I was thinking about situations like the nutjob in Nebada Las Begas during that concert that used the dreaded bump-stock to do his nasties. Okay, so everyoneās pinned down, you canāt shoot back even if you were packing (at risk of peppering a bunch of innocently-occupied rooms in the process), but one good look at where the bozoās shooting from, whip out Olā Blue, and give him a few multi-watt flashes to sear his retinas, and he wonāt be shooting anyone except purely at random. And then wonāt be able to escape without feeling his way out with a white cane.
Yeahā¦ that was bad. Amazing it disappeared from the news so fast too.
āThe dreaded bump-stockāā¦. Iāll have to assume that is sarcasm.
A bump-stock is good for nothing but to play with for the most part. If your trying to really hit anything specific after the second shotā¦. good luck unless you are highly trained & lucky. Itās more of a āpray & sprayā device.
Heck, you can do the same thing with a rubber band or a belt if you know what you are doing.
That could possibly work wellā¦. :+1:
But, on the other hand, if you have located where the ābozoā is; Pb & Cu could work well also.
Questions (not being sarcastic and also not suggesting itās a good idea either):
Would the buildings glass not stop said laser from hurting people behind it (so only the shot out window rooms occupants were at risk)?
Would the buildings glass reflect the laser and have it still be powerful enough to do damage to people still on the ground?
