Please point something out to a thicko like me , whatâs the difference between party strobe & tactical strobe ? To me they are the same & the only difference is the tactical strobe is brighter , am I missing something?
Usually Tactical strobe alternates between 2 different rates, but on the FW3A Tactical seems to have a longer On pulse which is more irritating plus it is brighter. Party strobe has a short On pulse that can make things seem to move in slow motion and is not irritating.
I remember because I repeat myself a lot. I say how to do a factory reset pretty often.
Factory Reset
With light turned On, click 4 times to enter ramp config mode. At the prompts (fluttering light), respectively, click 1 time, then 21 times. If there is a 3rd prompt, click 7 times (this is seen when in stepped ramping mode).
My FW3A from the first batch died last night. I was using it at work (at pretty low power, below 350mA) and all the sudden it got stuck on, I could go above 350mA but now below.
I took it apart today and found one of the 7135âs completely shorted between output and GND (I did have to strip them all to find that).
Got it going again with another 7135 but I think for many thatâs above the level theyâd be able to diagnose / repair.
Not upset in the least, I jumped on the fw3a train from the beginning, I knew going in there could be problems early on. Whatâs odd is all the soldering looked great, no bridges or solder balls or anything that stood out, no excess flux, nothing⌠That one bad 7135 seemed to die internally with nothing triggering the failure other than use/time.
Again not a complaint, donât even plan to contact Neal, just reporting here. Allâs well again.
7135 chips do seem to have a reputation for dying recently. I wonder if the clones of a clone of an original chip are just getting worse and worse. We may have to step up to using the more expensive (couple of cents more) resistor/resistor bank designs instead of 7135 chips. Reliability should be better and thereâs no upper voltage limit of around 7 to 8 volts.
Thanks Jason , the party strobe is more irritating to me because itâs not bright enough, I can get both strobes to freeze a fan ,although I donât think theyâre stable (in frequency speed )because it needs adjusting now & again to keep it froozed.
Edit
It must be the 3 fans Iâve tried it on thatâs not stable in speed.
Unless the frequency is changing slightly as the cell gets depleted or as the light heats up & cool ?
Ordered a full ti version. Probably going to swap in 7a xpl Hiâs to keep the heat down a bit. Strange this led is not an option anymore, seemed popular.
That is a tricky question, for me at least. I have to think about it. The output frequency for the strobe is controlled by the MCU internal clock which I believe recieves power from an LDO (low drop out voltage regulator) at about 1.8v. So the MCU has stable voltage and can output stable frequencies and pulse rates. It has itâs own built in precision clock/timer.
The reduction in brightness as the battery goes down is all due to factors between the battery and led and not due to anything the MCU does. The MCU still pulses the FET and 7135 chips the same rate as always regardless of battery voltage, but the lower battery voltage across the FET and 7135 chips equals less brightness. This is a direct drive design after all.
Boost and Buck drivers actually increase and decrease the voltage going to the Leds which is why the brightness level is stable to a certain point then steps down like a staircase (Boost). With Buck it has stable output until it falls out of regulation then the output slopes down. With direct drive the output starts high and then immediately starts to slope down in a smooth line.
Max regulated is about 2.8A and Turbo is about 9A (depending on the leds and battery). So thatâs a 3x jump in amperage. This also results in about a 3x jump in lumens, from 1000 to 3000. This is a big jump (both lumens and amperage) on paper, but not a big jump to your eye. Itâs like a typical jump from High to Turbo. You practically need to triple the output for your eye to see a noticable jump in output. Itâs just the way out eyes and brain process light. Not as linear as you might imagine.
It sure looks like a big jump in output on my light.
I often hear the âlogarithmicâ rule thrown around here. Iâm not sure I completely buy it. It makes a lot of sense for lower outputs, where the pupils of your eye constrict (letting in less light) as the flashlight output gets higher. Iâm not sure it makes as much sense for high outputs, where your pupils are already maximally constricted. It doesnât for me, anyway. On all my lights, I see a big difference between 500 lumens and 1000 lumens, and 1000 lumens and 2000 lumens. Itâs extremely noticeable, not just a little bit. Doubling output gets more noticeable the brighter the light is to begin with.
Iâm not sure Iâd characterize 2000 lumens as âtwice as bright to my eyesâ as 1000 lumens. But, itâs closer to twice as bright than it is to 1.4x (or whatever the âruleâ is).
