Hum, unless they put a taller rubber tailcap, it should work well! Both my old and new versions tailstanded correctly!
Have you checked if there is any āholdingā spacer between the switch and the tailcap?
If not, it may cause the tailcap to protrude a bit !
Also, that seems a photo from the old version not the AA 2.0!
Even in AliExpress where I bought mine, it has the bunny tailcap!
I looked and it appears I replaced the tail spring with a stiffer BeCu one. So now when I really crank the tail cap down it pushes out on the switch just enough to make it wobbly. If I loosen the cap just slightly it will barely stand on its own so I guess it was my own doing after all.
Glad you found what was wrong
These lights have room for mods, but they need to be precise, otherwise weāll end not having a good final result!
Hope you can solve it and make it tailstand
BTW, can I ask what mod did you do? :innocent:
I am quoting this because a fellow member asked me about unscrewing the pill of the Tool AA (and the Tool 25 is the same)!
Please be sure that when you unscrew the pill, you use thin tweezers and you rotate it to the right, not the left!
The pills are not glued, so it is just a matter or turning it to the right!
Thanks bansuri!
I quoted your post because I remembered someone (=you ) had posted that information into the thread and I wanted to make it more visible as I forgot to mention that on the text review on post #1!
We are normally used to loose the pills towards left and tighten towards right, but these 2 lights are the opposite (need to turn it clockwise to unscrew)! So thanks of the heads up, and also for the edit/clarification on your post.
Not this one, I think I learned that lesson on a tailcap switch on another light. Now I check both ways.
Glad these arenāt glued.
Still havenāt modded, not sure what to swap to. So many choices.
Been using it as-is, tint is acceptable for a cool tint. Weāve seen worse.
Ufff, I thought you had a problem with the Tool! :zipper_mouth_face: Glad you donāt! :+1:
Nop, nothing is glued, just like on the V1.0! It is very mod-friendly! Apart from those flaps in the driver/pill and the smaller diameter of the aluminum MCPCB, which are also easily modable!
The CW tint is not the worst, specially if compared to the V1.0 that had huge tint shift (and that terrible PWM)! The new versions are improved and I only wish they had no memory! I will put a new driver someday to solve that :innocent:
Like this light (tool aa v2.0) apart from UI. I thought with the memory mode, I can leave it in Turbo. But when you switch off and on with in 3 seconds it will advance to next mode. Wish it has double click and triple click access in UI.
Is there anyway or mod for direct access turbo or strobe?
Yup, between 0-3 seconds it changes the modes if you click ON <> OFF ! Not the worst but Iāve seen better!
With this driver it is not possible to reach those 2 modes immediately. Well, the turbo only if you leave it on that mode before switching OFFā¦The strobe, not possible.
For that youād need to change be the driver for a more flexible UI.
Finally . iāve got my Tool25 last week. Didnāt have much time to play with but i must say iām happy itās easy to mod.
Several driver sizes can be squeezed in
Yeah iām also in stand by waiting for MTN but for other stuff.
I have assembled my requirements for 2S Bistro driver 15mm so i will place an order with Lexel. And iāll take one 15mm Bistro single cell for ToolAA
Emitters wise iāll try Osram W1 in ToolAA and shaved 351D 5000K 90CRI in Tool25
