Just found this forum and this post. I, for the life of me, cannot get my EBD-USB+ to work … I think my computer see’s ‘it’ … it autodetects com port 3 (and if i change the com port in the deveice manager settings the software seems to ‘follow’ the new com port) but the software simply will not connect to any load I put on it … i get nothing.
I can confirm that the load tesing, USB female slot works, as I can attach an actual load to the male usb out and it works off the source battery i attach to the usb female input plug. And if i assume that the micro-sub port to attachj ti to my computer, then i am not sure what’s wrong.
I kind of feel like it’s a computer/com prot issue … i’m using windows 10 and i’m not sure how it treats a USB plugged in device as a com port (is there a setting i need to change). I will try to try using older EDB-USB software and i will try a firmware update … if i click on the firmware update buttonm in the software, it actually doesn’t let me select any type of device …o perhaps my micro-usb connection isn’t working? I’ve tried 2 different cables but will try a third to see if that works.
I have EBD-USB(not plus) for about 2 years, and I’m not happy due sudden disconnect from COM-port. Software indicators become frozen, and device continue to draw current. Very disappointing to begin spoiled test again and again. Tried everything, different PCs, Windows, cables, drivers. Defective device? Don’t know. Not using now. Got TEC-06, run it w/o PC connection.
Sad. Good device...
Btw, to clean out COM ports on Windows 7/8 (not sure abt 10, make backup first) there is a script, just as example:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\COM Name Arbiter] "ComDB"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00
COM assignment will be reset, make sure you don't have vital things there (printer, modem, etc)
Hi friend. I have ebd-usb+. But i have a big problem. I changed the calibration setting of the device.But dont fix it.Can the device be reset? Can it be restored to its initial settings? Can you help me pls.
If you use the EBD-USB+ software (EB Tester), I think in the Calibration menu, there is a Reset button — have you tried it?
(I have not personally tried calibrating or resetting my EBD-USB+ though, so kindly report here if the Reset button did something for your unit).
EB Tester software has another update (it now indicates Build 2020-01-01) - as usual no changelog and likely just some very minor unspecified changes since the executable file seems to still be similar file size)
(when installing, I find that you need to uninstall or rename/delete the old EB.exe file (default in C:\Program Files (x86)\ZKETECH\ folder), otherwise, it didn’t seem to update my previous EB Tester Software even when it appears to install successfully…)
I have a couple of questions ( for HKJ ) about this tester for batteries is possible to just use the current measuring capabilities of this tester with out using the on board load ?
How easy would it be to power the battery voltage separately from the battery tester from the USB connector to the computer
The reason I was asking about if the load of the tester could be disabled is because what I have in mind doing is setting up a battery backup power supply charging and discharge logger for power supply output
I have there battery tester machine and just love using it for that purpose but I do not want to modify this tester
I would prefer to use this device and modify it for the purpose that I was just talking about
Would this interfere with using more than one EBD USB tester in series with a common ground is there a way to isolate the common ground and the tester to work correctly
I did some measuring between two separate EBC-A10H units and the grounds connected will not let do this without using two different computers then I could use it in series to test BMS balancing board like I want to do
I am a little disappointed that I can not do this with a single computer but I can work around this inconvenience
I now have to buy two of EBD USB units and make a setup for this type of testing
And do some testing once I get everything setup I will post the results when I have the test results finished
I was using the EB software yesterday and this is the first time I have had software not wanting to work correctly at all
First it would show on the computer screen that the unit was connected when unit screen would not show connect to PC
Or
The computer screen would show that it was not connected but the unit screen would show that it was connected to the PC
Or
If both would agree that it was connected the unit would not turn on the load
Or if the unit turned on the screen would not show any load being applied but shows voltage readings but no graph movements on either voltage or current
So I would turn the unit off and wait 30 second and turn it back on then it refused to connect unplugged the USB dong and reconnect it still would not do anything finally got it to work
For one battery test on unit One but then the same exact thing would happened to unit 2
So I restarted the computer and both units and everything seemed to work okay after that
I seem little cliches with this software before but not like this before and I have used it before in marathon runs for a week or two using it 10 hours days and sometimes even more hours running than that and had not this much problems with it
Yes this time it has been on a three week marathon or longer more hours running events so I do not know if this has something to do with it or not
One note the computer and the battery testing units are on a battery backup unit and the computer is running 24 hours a day and the battery testing units are also running 24 hours a day
One other note the computer is set up so the computer screen shuts down after 6 hours but the hard drive is not suppose to shutdown but I think I might have caught it shutdown when it was not suppose to be so I am not sure if it might be a computer issue causing the problems
