Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1407 posts / 0 new
1stein
1stein's picture
Last seen: 5 days 1 hour ago
led4power wrote:
1stein wrote:
Neven, still waiting for your LH351Ds 4000K 90 CRI. What’s the forecast? Is there a point in waiting longer or I should look for something diffrent?
I doon’t plan to stock that LED anymore, unless I find really good tint, but chance for that is close to zero based on my experience. LH35D is really nice LED overall, but it’s not the best at anything (CRI,output,tint, overdriving…) so it’s not very interesting for flashlight modders.
I see, thank you for honest answer, appreciate a lot. I was very curious how it works dedomed, furtunatelly I have 2 spare left Crazy (but not much room for fails)
contactcr
Last seen: 8 hours 53 min ago
When you slice the dome close it falls almost exactly on BBL or slightly under. With a lot of current it doesn’t shift much either. Only problem is output takes a decent hit and some flat LEDs are harder to focus
1stein
1stein's picture
Thanks for hint. Is the LH351 dome hard? Heating up then slicing works good for this one?
djozz
djozz's picture
Last seen: 18 hours 34 min ago
My way is without heating: I have a series of 4 washers that fit between the led and the solder pads of the ledwires. They go from thick to thin, with the thinnests one the correct height to slice just above the phosfor. I use an oldschool two-sided Wilkinson razorblade to slice layers off the dome. I learned how to keep the blade straight while cutting and that for the last slice the angle that the blade makes makes a difference. Also the thickness of the solder layer is a factor involved in where the final cut ends, I try to seat the led as flat on the board as possible to get the same height all the time. Try practising on a wasted led.
viblet
Last seen: 1 year 6 months ago
Sounds like it will be added to my kit Smile
1stein
1stein's picture
Very precious hints. Appreciate a lot Beer
contactcr
I do the same as djozz only with 2 or 3 washers. If you try it with just one the edge of the dome will likely tear off at the end of the cut. As djozz mentioned the solder height is a factor if you want a close cut but probably even more important is to try to use the same type of MCPCB each time. I have a 20mm one I use that has never had solder on the LED +/- pads so the washer sits flat/the same way every time.
1stein
1stein's picture
Actually it’s good to know others experience similar problems, I was even thinking of getting something thinner than Wilkinson razor, but the trick with double / triple washer is definitely worth trying. Many thanks.
DavidEF
DavidEF's picture
Last seen: 2 weeks 6 days ago
I’m not sure everyone understood what djozz was saying. I think he’s saying he uses a thick washer to slice first, then a slightly thinner one to slice a bit more, then a thinner one again, then the thinnest one gets the last slice to be the right height.
- The YKK Philosophy
KevinZA1988
KevinZA1988's picture
Last seen: 4 hours 8 min ago
Neven,
Do you know whats the tint bin of your 3000K Luxeon V2’s? On the datasheet there is 5A, 5B, 5C, 5D, 3U, 3L in 2700K, 3000K, 3500K.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manker MC13, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
led4power
led4power's picture
Last seen: 53 min 2 sec ago
I don't know exact tint bin, but I've never seen Lumileds LEDs available in narrow tint bin range,they are only available as 3 or 5-step MacAdam ellipse.
KevinZA1988
Thank you
1stein
1stein's picture
Thanks for pointing it, now it’s crystal clear.
djozz
djozz's picture
Thumbs Up I think that language to describe technical procedures is the most challenging type, perhaps even for native speakers.
alberto7
Last seen: 6 days 23 hours ago
I see clearance sale in some copper mcpcb DTP, ther will be replaced or what is the reason?
led4power
led4power's picture
They will be replaced by new design,fully gold plated this time, so price will be a little bit higher (similar to 3030 DTPs). Existing PCBs at reduced price will be available until stock is exhausted.
KevinZA1988
Hi Neven,
Will you also be making a 5050 16mm DTP MCPCB?
led4power
led4power's picture
I don't plan to have 5050 pcbs anymore, only two popular LEDs use them these days: SST-40 and XHP50.2, and I don't stock any of those, so it doesn't make too much sense to have pcbs and no LEDs.
Luxeon V is IHMO better LED overall than SST-40 so I don't want to stock two very similar LEDs, XHP50.2 has ugly beam tint - don't want to stock those either for this reason.
KevinZA1988
It makes sense… Thanks
contactcr
LD-B4-20 ETA?
Scallywag
Scallywag's picture
Last seen: 4 hours 54 min ago
Someone gets it! Only passable excuse IMO for sst40 is dedomed.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
led4power
led4power's picture
contactcr wrote:
LD-B4-20 ETA?
10-15days, I'm waiting for some test rig pcbs.
contactcr
If anyone was interested in the L4P quad spacer for the X6 you might find this useful:
hodor
hodor's picture
Last seen: 18 min 42 sec ago
Damn it, I may just have to build one now Blushing
Question though, I haven’t been able to find the answer and haven’t built a triple yet so forgive me if this seems like a simple/noob question… I see the L4P triple spacer has a bolt and a spacer whereas others, such as kiriba-ru’s, just have the spacer. Why is that and is there a practical difference? I’ve gone through a number of X6 triple/quad build posts (including yours) but am still struggling to get my head around the role the bolt plays.
contactcr
The bolt keeps the spacer from spinning when you screw the bezel and it also ensures good thermal path from spacer to body.
KevinZA1988
I measured the newer batch Luxeon V with a Vf of 3.324V 6A, compared to the 1st batch with a Vf of 3.484V 6A.
hodor
hodor's picture
Still confused Blushing
What does the bolt rest against and what stops the bolt from gradually (un)threading on the spacer?
contactcr
You only drill the X6 shelf enough to fit the bolt so head of the bolt presses on the bottom of LED shelf. The inside of the spacer is threaded so it grabs onto that and pulls spacer toward top of LED shelf
led4power
led4power's picture
With hollow bolt method assembly is much easier because once you install spacer with bolt and tighten it, spacer cannot move or spin because clamping force is big which is also good for thermal transfer between spacer and body.  After that you can easily install mcpcb and driver.
With traditional spacer this is more complicated/messy since everything is loose and can move - source of clamping force is bezel (force "travels" through optics) - not optimal IHMO.
Buoyen
Last seen: 1 year 2 weeks ago
Hello!
I bought some of the last ld-b4hv, but I have a problem with the gate solder pad coming off the pcb. Happened on two different driver boards while I was soldering.
Figured I could solder the wire on top of the resistanse in the photo because it looks like they are connected (measured for continuity on a third driver board which I have not done anything to yet).
https://photos.app.goo.gl/XZFmWbA7ah21REVc7
Then something strange happened.
I’m using the mosx board with FET. When I measure for continuity without wires attached I have connection through the LED between + and “m” and no connection between + and -
https://photos.app.goo.gl/rH8gkK6qMFL68qeK8
As soon as I connect the gate to the mosx the FET is shorted out and I have connection between + and – even when the FET is not energized.
What is going on. Is my point for gate on the driver wrong?
The third picture I have attached (this is something led4power posted earlier in the thread) – why is there a wire on the m pad ?
https://photos.app.goo.gl/3Wrcuww2FqM647Rb9
