content:
From the moment of payment 20 days. Tracking full to post office. Packed super securely, as always with this seller. Inside the foam box. Cardboard boxes with tester marking. Included instruction with pictures and plugs with wires. I recommend the seller, i order from him not the first time
NEW SHARE
RD UM34C Type-C DC voltmeter ammeter
[Cool tester! Works fine, now you can check all your powerbanks! Many thanks to the seller and the manufacturer!!! The seller is very sociable and friendly!!! I recommend!] https://www.aliexpress.com/item/32880908871.html
NEW SHARE
RD AT34 USB 3.0 color LCD voltmeter ammeter
[Working tester! The accuracy of the readings was not tested, but i do not need special accuracy. The hood, the case is a good topic-i often carry with me (there is another tester in a simpler way. There are no these buns). A decent instrument! I’m happy… Bye!] https://www.aliexpress.com/item/32897200670.html
NEW SHARE
RD DPS5020 DC- DC Step-down communication Power Supply
[The parcel reached the Moscow region in 22 days, it was packed in a foam plastic box, the seller put a “crocodiles” gift the board with the installed elements looks good, it comes on plastic racks with internal thread, the converter works properly, but I had to dig into the memory settings.] https://www.aliexpress.com/item/32821185351.html
NEW SHARE
RD AT35 5 digits USB 3.0 color LCD Voltmeter ammeter
[Item arrived in excellent conditions. Works as expected. Here is a comparison between the new model (top) and the old one (bottom)] https://www.aliexpress.com/item/33022448123.html
NEW SHARE
[Cool tester. Checked its charging and wires, it turns out only one wire supports 2a. In general, i’m happy. The seller is well done, everything is packed on conscience.] https://www.aliexpress.com/item/32880908871.html
NEW SHARE
RD DPH5005 Buck-boost power supply
[There was no doubt about the correct performance of this device, so that immediately mounted in the backup power supply. I am very pleased with the purchase, i recommend.] https://www.aliexpress.com/item/32840324731.html
NEW SHARE
RD LD25 LD35 USB Interface Electronic Load
[Very fast shipping. Item received 7 days after placing order. The load works well. I like the fine current adjustment. The built-in display is handy and accurate enough for testing. I’ve already used it to test voltage drop on USB cables.] https://www.aliexpress.com/item/32882318330.html
NEW SHARE
RD UM24C voltmeter ammeter
[Delivery is very fast. The quality is very good, the screen is clear and bright can be seen even in the sun. The version with bt is a convenient program for monitoring on the smartphone. I recommend the seller and the product.] https://www.aliexpress.com/item/32845522857.html
NEW SHARE
RD TC66C Type-C PD trigger USB-C Voltmeter ammeter
[The trigger reached severodvinsk in 3 weeks. Packed well. Trigger in box, box in foam. In general, it came safe and sound. Installed on the phone the recommended program. Checked, works fine, bluetooth pairing with the phone. I’m happy. Seller and shop recommend.] https://www.aliexpress.com/item/32968303350.html
new share
RD DPS3005 DC Step-down Power Supply
[I buy the second module, the first was more powerful-5015, but it took another device. As the basis of the amateur power source-the thing is wonderful!] https://www.aliexpress.com/item/1000004279003.html
NEW SHARE
RD DP50V5A Step-down Power Supply
[Order not for the first time. High quality, fast shipment, good packaging. Buy, you will not regret! Seller thanks!] https://www.aliexpress.com/item/32596330856.html
