I’m in - I’d love for Astrolux to make some sexy 365nm UV beast.
I’m in. Thanks.
My dream flashlight is a headlight with 4x high CRI 4000K LED, 2x Li-ion on the back and Anduril UI.
I’m in
I would like an Astrolux zoomie. A high spec one.
I’m in.
Affordable LEP flashlight,preferably 21700 size.
I’m in.
I want a version of ASTROLUX MF01 Mini use 21700 battery.
I’m in! I would like to see Astrolux make a combination work light with a powerful flashlight attached. Nebo Tool makes some nice ones, but I think they need more power! Have a COB panel for flood and wide area attached to a flashlight with like 2500lm (xhp50.2?) But a nice beam pattern with moderate throw. Ron it off a single 26650, USB quick charge with ramping firmware.
Im in thanks!
I would like Astrolux make a nice AAA light that uses 10440 battery.
I’m in.
I would like that Astrolux makes a 21700 powered, 1,5 inch head, neutral white flashlight with high quality constant circuit driver and some great UI. Looking for running turbo mode almost until LVP kicks in.
I’m in , Would like to see 21700 small EDC FL.
I’m in
It would be nice if Astrolux could make a small EDC (AA) with a collar mode changer …great gift to elderly non flashaholics who may find it easy to use even with a bit of arthritis
Thanks Freeme and Astrolux
I’m in…happily try to destroy it underground on a few caving trips!!!
I’m in, I’d like to see a 2x26650 searchlight with a good combo of flood and throw.
I’m in
I would like an Astrolux to make a Ti pocket EDC light.
I’m in
I’d like astrolux to make an active cooling flashlight with more than 15.000lm and +1000m reach
I’m in. I would also like to see a LEP light that doesn’t cost an arm and a leg.
I’m in.
I’m in.
14500, anduril, side button, 3000K-4000K high CRI
I’m in!
21700, pocketable size, warmer tint perhaps?
I’m in. Thank you!
I would like Astrolux to make a 21700 light with a side switch, an XP-L HI emitter and a 40mm TIR.
Simple UI with 1 click ON/OF, ramping from moonlight to turbo, 2 click strobe, and 3 click batt.check.
Able to go max till the LVP kicks in. Inductive/magnetic type charger. NO USB plug and rubbers please.
Edit: and a slightly crenulated SS bezel. Sorry.
I’m in. straight or right-angled Compact 21700 single high CRI neutral white LED with a deep carry clip(please) that is not friction fit.
