I’m in…happily try to destroy it underground on a few caving trips!!!
I’m in, I’d like to see a 2x26650 searchlight with a good combo of flood and throw.
I’m in
I would like an Astrolux to make a Ti pocket EDC light.
I’m in
I’d like astrolux to make an active cooling flashlight with more than 15.000lm and +1000m reach
I’m in. I would also like to see a LEP light that doesn’t cost an arm and a leg.
I’m in.
I’m in.
14500, anduril, side button, 3000K-4000K high CRI
I’m in!
21700, pocketable size, warmer tint perhaps?
I’m in. Thank you!
I would like Astrolux to make a 21700 light with a side switch, an XP-L HI emitter and a 40mm TIR.
Simple UI with 1 click ON/OF, ramping from moonlight to turbo, 2 click strobe, and 3 click batt.check.
Able to go max till the LVP kicks in. Inductive/magnetic type charger. NO USB plug and rubbers please.
Edit: and a slightly crenulated SS bezel. Sorry.
I’m in. straight or right-angled Compact 21700 single high CRI neutral white LED with a deep carry clip(please) that is not friction fit.
I´m in.
I would like to see a triple 21700, 1Lm start, ramping,with good balance throw & Flood.
I’m in
Astrolux have achieved thrower, flooder and EDC lights already so I would like ASTROLUX make headlamp with nice efficient moon mode running for months (like Zabralight) and keep low production cost for mass sales.
I’m in. An affordable LEP flashlight, or active cooling flashlight. Thanks!
I’m in.
21700, 4000k Tint high cri thrower.
I’m in
I’d love 21700 compact lights with good power (triple or quad or 50.2 or 70.2) in NW or WW tints. No usb charging necessary. Mostly flood with a little throw. Thanks!
I’m in
I’d like some small 14500/AA or even smaller AAA headlamps.
have a look at the manker ones…
We use them as back ups for Caving and in our go bags… Amazing little things with good outputs/runtimes on 1 battery… or look for the Fenix HL50 as that has an adapter so you can run it on a AA as well(uses CR123a normally)
Again I havethe HL50 usually one in the bottom of my caving gear and one in my go bag…
I’m in!
Astrolux could make a 18650 headlamp, 2 emitters (throw/flood), high cri, Anduril
I’m in
Big throwy floody torch like the MF01s, but with the ability to split from the battery pack and snap onto a headtorch with a (considerably) smaller battery.
I’m in please, I’d love for Astrolux to make a tube light similar to the emisar D4 in form factor but also like an Fw3A, so quad, with anduril and 21700 battery with the same rgb aux secondaries from D4 but with tail e-switch of the FW3A
PRETTY PLEASE
