If money is not a problem, which flashlight would you buy for the rest of your life?
yeah, my point is not asking “what is perfect flashlight”, but “which flashlight is perfect for you ?”
maybe Satan suddenly appears in front of you and ask you this question :smiling_imp:
I would consider myself fortunately if that was the only question Satan had for me :slight_smile:
Yeah, you could, you even can require Nasa to make a custom light from Moon or Mars rock. No one gonna stops you. But dont regret your choice :smiling_imp:
All of them are perfect as they all have their own characteristics that make them perfect for a certain situation. Maglites are great throwers. You can throw them against attackers, bringing darkness into light. Other flashlights are good at bringing light into the dark. Depends on what is needed.
I would get a team and develop my own light. Control ring like jetbeam with lvp and battery check. Fancy design and hi end materials.
I’d have a Copper version of ALL the torches I own and use.
One off.
Probably a copper vers, Of my Imatent DN35. with DN70 as backup.
They’d do ALL my eyes can see.
There’s not really any need for me to get super spread. Beam.
I can’t physically see that far.
“If money is not a problem” means not “to buy”, but “to costruct” for BLFers. :slight_smile:
LEPs are on the rise and have potential to replace the LEDs…but are not there yet.
I’m not sure if there is ever a good time to buy the last light but I’m sure it’s not now.
But if I had to - that would be a custom zoomie. Beryllium body, diamond shelf/PCB, custom optics, EAL7 UI…just all the usual high-end stuff.
Ooh! I didn’t think of that!
Etched nickel-iron meteorite metal and PVD diamond coating it is :slight_smile:
I could carry anything that I find right now,life is too short to not carry my favorite now!
SC64W for me!
Cool Fall Tri-V
FW3A217RGBM
FW3A with a couple minor tweaks
-at least 10mm shorter
-(with 18650 or more energy level)
-side switch
-longer turbo times
-head same size as body
(probably all impossible)
My choice… would be to buy what I like now the FW3A or D4V2 and then work on finding my favorite led in both. I have 3 of the FW3A’s and they are led testing platforms and one EDC. Once I find the led I want, it will go into the D4V2 as well. I like good budget lights because you can change them often when a better one comes along. But I suspect that these 2 will be with me for a good while!
I would get the FW3A. atm my wallet believes I shouldn’t buy another light I don’t need.
Never had a Cool Fall, but thought a Cool Fall and my HDS rotary as you did.
Why Imalent MS18 R90TS kit keep showing in my head :person_facepalming:
I would buy a GT70. I don’t have any need for it, to justify spending the money out of my “real life” budget, but if money were no object, that’s what I’d get.
Modded FW3Ti/Cu
-UI updated with a tactical mode (direct access to turbo and /or tactical strobe)
-Guarded rubber tailswitch
-Crenelated bezel
-Improved cooling
-Heat treated Ti for the rainbow color
