I have seen them around in ice blue but I don’t own one to know what color that is exactly. I just assumed it was like a white blue, dim or light blue.
You already know what the trit color ice blue is, I kind of figured it was like that. ENEDED - #22 by Tom_E
Only just came across this switch, its amazing work!!
Will it take much for a board like this to be implemented as an electronic switch with a small momentary switch instead of a clicky? Im imagining that it needs a bit more electronics to store the switch state.
Mechanically it also wont be the same either… but this thought comes about for a replacement switch for a V10R or other DIY projects.
Forgive my ignorance but where do the bleeder resistors go on the boards? I’m similarly interested in building this switch for use with an Mtnelectronics H17F. Are they soldered in addition to the cited components or in place of some them?
The bleed resistor goes anywhere you can get battery positive to battery ground (outside driver ring) on the driver. Its a additional component that needs to be added in some drivers. Some work without a bleed resistor.
Here’s a few pics.
I’m having a bit of trouble ordering the boards from OSH Park. Im using the tailcap switch and LED board in an S2+ Triple but I cant see how I change the board thickness from 0.8mm to 1.6mm?
Is this necesary when using this system in an S2+ host?
During the checkout process you select the “service” you want: 1.6mm standard 1oz, 0.8mm 2oz, after dark, medium run, or rush order. Just pick the standard 1.6mm 1oz service.
Would anyone be able to suggest an alternative Super Barrier rectifier to the one suggested (SBRT05U20S3)?
I am having trouble tracking on down on digikey.
The super capacitor will provide ~20 uAh to 2 volts so it will likely keep the board functional for a few hours. Then what happens? The light may no longer be operational for a while after that.
