Yeah, well, they DO advise to leave the tail cap in place and not tamper with it… so replacing the tail cap en masse would be an invitation to catastrophe. Those un-enlightened that have tampered with the tail cap have had a high rate of glitches because of it.
I thought I asked Neal to be sure my copper variant had this button but maybe I forgot.
Maybe if we ask nicely and promise to be careful with our FW3Xs, Uncle Neal will procure metal buttons for us to buy? I’d like one with the LuminTop rabbit. And after all, Neal already sells accessory glow buttons.
Well, I got to thinking (not always a good thing) and decided to try a different battery than the one Neal shipped with the light…. (it was marked as a Murata). I removed the Samsung 30Q from my original Gray FW3A and tried it in the FW3T+Cu…. and it works perfectly. There is nothing wrong with the light, but it really does not like the green battery Neal shipped. That same battery does NOT work in my original FW3A, but it DOES work in my Emisar D4 and a Sofrin SPA32v2.0 I had laying on the bench.
Again, there appears to be nothing wrong with the FW3T+Cu that Neal shipped… it just does not like the battery.
Wanted to swap in the xpl hi board I had laying around from an fw3a, but the boards in the ti lights are much thicker. So I went with a sst20 3000k reflow.
Full ti indeed. I like the extra weight in combination with the titanium. Feels like a real tool now. I think more weight of the ti/cu would make it to heavy me.
Probably gonna have issues with the wife over this one but I need an FW3T. Any suggestions on which LED choice (3D, SST, or 219D) would be the most efficient (least heat) for the Ti light?
Here’s my 1A FW3A from Neal. PM with order number sent.
General info including LEDs can be found here . . .
I use white light flashlights at work for inspection and forensic examination. In general, I’ve found that warmer color temperatures give truer color rendition and cooler temps show details and flaws better.
My wife knows lights are tools. I’m getting several FW3Xs for multiple dedicated uses: first aid kit, door safety, work, and personal use. My wife is totally on board with that plan. We don’t have a lot of disposable income, but we agree that some things are worth the expense.
If it works out, maybe a way to get your wife to work with you is for you to have her pick out a FW3X for herself while you are getting your Ti version?
Again from my experience, try not to be disappointed if your spouse doesn’t want her own flashlight. But, she will probably appreciate you having one in time of need.
I think the xpl-hi is going to be the most efficient (lumens/heat) of the bunch…
I could be wrong… I’m thinking that since it has the highest output of the bunch, it puts out more lumens at the same power level. Following that logic, you’d be able to use less power to achieve the same amount of light.
In my regular (or “EDC”) use, it doesn’t matter too much as I don’t leave these smaller flashlights on turbo for very long or very often. I typically use them for a few minutes at a time and usually in the low - mid range of what they are capable of. When I’ve needed them for longer, I didn’t need them set at their brightest anyway. I usually go for higher CRI with good tint (the SST20 option in this light has pretty decent tint and high CRI from what I hear) for this type of light because that is more important to me than heat generated at higher levels. That said, I do like the xpl-hi 3Ds I have in my first one. Not really a bad option here no matter which way you go.
