What is the standby current?
PB2 was terrible.
PB2 was terrible.
Patience, grasshopper.
I am starting to love the PB2S
Hope the price drops
Thanks for showing me the info about the low amps mode. Great!!
I walk the rice paper gently.
I just got one, and it’s nice! The “official” link is
XTAR PB2S 18650 & 21700 Fast Charger & Power Bank
which has anigifs to show how it charges/discharges.
True, it’s bigger’n the PB2, but this donk fits 21700s, too, that’s why.
Hell, today I needed to charge a 26650 (Cometa) and it fit it just fine. Sure, just one cell only, and the cover won’t fit, but to be able to charge even a moose like that in a hurry? I’ll live with “larger”. :laughing:
And there are 2 separate independent channels, so you can put one nearly-topped-off cell right next to one that’s almost dead, and there’ll be no problem.
The side-button lets you click to see the connection spex, then for battery 1, then again for battery 2.
Where did you get yours from? i see
This is my first XTAR charger, and I’m happy with it.
Oh, and it charged my phone just fine. Dunno about “The IPhone Problem”, but my normal phone worked fine. Was at like 36% or something, topped off, drained the PB2S down to 65% or so. Ymmv, of course.
Lightbringer
So where did you get yours? I see Illumination Supply now has them for $17.52
The XTAR store.
The XTAR store.
Thanks
If anyone’s interested, I did a charge comparison against a wall charger and another power bank.
@UserM4 thanks!
The PB2S is already out of stock on Aliexpress. The owner told me the red ones should be available next week, the black ones will be delayed.
It is back in stock!
Just ordered a res one. Thanks for the heads up!
Does someone have first impressions of the magnetic latch? Are the magnets strong enough to hold it securely in place even when tossed in a backpack?
Yeah, you need to actually pry into the crease between door and body to open it. It’s not likely to just pop open on its own.
Illumn has been advertising QC 3.0 AND PD charging, but the official specs don’t mention a 12v output. Judging from the OP, I suppose it doesn’t actually support PD?
Xtar PB2S Charger & power bank This is a 18650/21700 LiIon charger and power bank from Xtar with support for QC. It arrived in a white cardboard box with specification on it. The box contained the charger, a usb cable (A to C)...
Check out this review as it talks about the 12v output
The cons are high parasitic drain, inaccurate display, batteries must be able to handle 2A charging
that’s not all the cons:
https://lygte-info.dk/review/Review%20Charger%20Xtar%20PB2S%20UK.html
5V-2,7A
9V-1,7A
12V-1,2A
Not full compatible with Quick Charge 3.0
I knew I forgot something.
Also expensive
Also expensive
I purchased from here - 28.07€ |XTAR Power Bank LCD USB Ladegerät QC 3,0 Typ C EINGANG PB2S Für 18700 20700 21700 18650 Batterie/NUR PB2 Batterie Ladegerät FÜR 18650|Ladegeräte| - AliExpress
Message the seller and he’ll send you a $5 USD discount coupon
