Hi there all of you.
Has anybody had any experience of the Lazerbrite range of lights. I searched the forum and couldn’t find anything about them, sorry if I missed it.
Available in a wide range of colours White one end and white or another colour at the other. Plenty of extras to keep you amused as well.
Runs on CR2032 Batteries.
The entire blurb from EDC Gear .co.uk -
This LazerBrite LED flashlight has one glow tube, two flashlight heads, and batteries included.
When purchasing the Lazerbrite you can select the two flashlight colour heads of your choice from the range, for example (White/White) for two White heads or (Orange/White) for one Orange and one White head.
The Multi-Lux unit, unlike the single mode light, comes with low, high, and flash modes. To switch between modes, simply twist the flashlight head in either direction.
The Multi-Lux Unit comes in a six colors as well as infrared, and has multiple uses. Not only can the flashlight heads be pointed into the glow tube to create a bright glowstick, but the LazerBrite is also a waterproof flashlight and can be used in the rain or for diving.
By turning only one of the heads in toward the glow tube, the user can also create a single focused beam of light. By using one of the many LazerBrite accessories, one can create an LED lantern, or tie the light to a nearby object.
The heads can also be taken off and shared by two people. The Multi-Lux also has the advantage of being an excellent marker light, as the flashing mode is perfect for marking campsites, cars, or the position of others for navigation or emergency situations.
Furthermore, the LazerBrite is a tactical flashlight, which means that it is both durable and easy to use. Perfect as a piece of camping gear, for biking, as a military flashlight, or even for use around the house, the LazerBrite Mutli-Lux unit is an innovate tool for everyone.
- Features
Two Flashlight heads (colour choice available)
Three modes, low, high & flash
Dual mode lighting, flashlight beam and/or glow tube
Waterproof to 50 metres (165 feet)
More powerful and longer lasting alternative to Glow-sticks
Runs for days on one set of batteries
CR2032 Batteries included
Made in the USA
- Useful for
Camping
Military
Night Navigation/Map Reading
Cycling
Vehicle Emergency/Breakdown
Boating
Survival Kits
Home Emergency/Powercut
Night Hiking\Outdoor Pursuits
- Benefits
Lightweight | 4.6 oz / 130 g
Long lasting | 300 hours of bright usable light
Can operate for days on one set of batteries
Over 1,500 10 minute signals in one package
Reduce your load | Replaces multiple chemlights
10 year battery shelf life
- Features
Patented 360 degree rotational switch
Three modes of operation: High, Low and Flash.
Waterproof design
Versatile modular design
Tough polycarbonate housing
Available in 6 visible colors including Gen III compatible Infrared
Made in USA
- Functions
Emulate chemical lights / glow sticks
Operates as a wide angle flash light
Create a focused spot
Separate into independent lights sources
Marking / Landing Zones
Area Lighting
Not exactly budget, not mine anyway, but an interesting concept and probably less costly in the long term than glow-sticks which can be wasteful as you can’t switch them off.
Oh burgger, that’s some more gear on the want but don’t need list, a long list is that.
Lazerbrite’s website.
