The making of the BLF UC4 charger: the start of a new venture, INTEREST LIST, UPDATE 7 (Ramping up slowly...))
1568 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 2 days ago
39$US would be a superb price, but 49$US is more realistic.
Pete7874
Pete7874's picture
Last seen: 8 hours 30 min ago
That’s fairly reasonable.
I’d add reverse polarity protection, too, if not yet mentioned.
BlueSwordM
Yes of course.
It’s such a basic feature that I forgot to put it in.
SIGShooter
SIGShooter's picture
Last seen: 3 hours 43 min ago
BlueSwordM wrote:
Final features that will probably be included:
10. Manual low voltage recovery for normal lithium-ion cells
Below 2,5V, maximum charge rate of 100mA.
Below 2,0V, maximum charge rate of 50mA.
Below 1,0V, maximum charge rate of at 25mA.
How would it differentiate between NiMh and an over discharged 14500? Probably something simple that I’m overlooking otherwise the NiMh will be charging for a long time.
BlueSwordM
This is why I added manual to low voltage recovery.
Lexel and the other guy did have a point that even if my method is very safe, there is still a risk, even if it’s 0,00001%, so I decided to change it to a manual setting below 1,75V.
Barkuti
Barkuti's picture
Last seen: 1 day 15 hours ago
Dot matrix LCD screen? Smile
Now that I'm here I will say that for accurate internal resistance measurement cell voltage needs to be measured right at the battery terminals. I mean, a 4-wire setup like in battery testing holders (example). Give up on this @#$% being fully accurate otherwise.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
SIGShooter
Ok..so it will assume NiMh if below 1.5v or so? That would make sense.
AguassissiM
AguassissiM's picture
Last seen: 2 weeks 17 min ago
For price see post #277
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 10 months 2 weeks ago
At BlueSwordM
I would extend the input Voltage up to ~30V. The most used PSUs have 12V and below. Above there is not much compatibility gain up to 20V. But like it was said before many Trucks use 24V and many industrial used PSUs are also 24V. Next step would be 48V but i think this will only add more costs and will not gain much options.
But to raise the possible input voltage above 24V (to be a bit more save from voltage spikes something arround 30V) would give the user much more options for PSUs and also the option to use the charger inside a Truck without any other converters.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
tatasal
Last seen: 3 hours 44 min ago
I remember my Opus, when powered by my 12vdc cigarette lighter aux power, loses its screen data when the car is started, resetting the charger to its default ‘Charge’ mode due to the momentary loss or drop of voltage, going to as low as nine dc volts when starting, especially with diesel engines.
I wonder how much minimum voltage is required so as not to lose data and re-starting ?
adam7027
Last seen: 2 weeks 3 days ago
Some extras that would be very nice, but not necessary if costs exceed 49$US with the below feature set.
1. microSD card slot for graphs.
2. Bluetooth functionality.
3. Charging/discharging graphs to a USB drive.
Feature freeze will occur at 11:59PM EST.
Please forgive me for chiming in during the last day, but I would like to suggest a few more things.
Quote:
1. Adjustable charging current (0,05-0,10A-…-3,0A) in 0,1A steps.
This should be in 0.2A steps above 1.6A and in 0.05A steps below 0.3A (more convenience).
Quote:
2. Support for multiple chemistries (NiMH, lithium-ion, lithium ion HV, LiFePO4).
Lithium ion HV (4.35V) is fairly uncommon – there could be also NiZn included, as it is very easy to implement (charges almost like a Li ion, just the target is different).
Quote:
3. Temperature monitoring (45C max below 2A, 60C max below 3A).
For better NiMH termination, sometimes -dv/dt termination is too late, and cells are getting cooked extensively (lower currents need lower temperature limits). Will you include a method for both voltage and temperature based termination?
Quote:
4. 4 cell channels, with support for AAA sized cells all the way to the largest 21700/26650/D cells up to 78mm length.
There could be one plastic adapter accessory included with additional springs to host some of the very small oddball li ion cells like 10180, 14230 etc.
Quote:
5. Active cooling if temperature exceeds 45C, and if all channels are active above 2,5A.
Double d=5cm fans, and very good set of heatsinks could be necessary – (for discharging at ~16W power).
Quote:
10. Manual low voltage recovery for normal lithium-ion cells Below 2,5V, maximum charge rate of 100mA. Below 2,0V, maximum charge rate of 50mA. Below 1,75V, it has to be manually activated. Below 1,0V, maximum charge rate of at 25mA.
I think, these rates are only meaningful for bigger cells (21700, 26650), for smaller cells, these maybe would be too harsh.
I would suggest these:
Below 3.0V, maximum charge rate of 100mA. Below 2.5V, maximum charge rate of 40mA. Below 2.0V, maximum charge rate of 20mA.
Below 1.75V, it has to be manually activated. Below 1.5V, maximum charge rate of 10mA. Below 1.0V, maximum charge rate of 5mA.
I would also add, that for each charging bay, if a battery is inserted, but no program started, the charger is required to not drain the battery (even if it is just a few hundred microamps).
Quote:
11. Adjustable max voltage for lithium ion charging: 3,65V-4,35V in 0,05V steps.
I would make this chemistry dependent.
lithium-ion: 4.05V – 4.20V
lithium ion HV: 4.15V – 4.35V
LiFePO4: 3.40V – 3.65V (I saw an article somewhere, which mentions, that at 3.4V, most of LiFePo cells are ~99% charged)
Quote:
12. Storage charge mode: 3,6V. Lower would be better, but it is too low otherwise for most people.
There could be more than one storage targets (different requirements). I would suggest to let the user set the target voltage in a range of 3.5 to 4.0 V (by 0.1V steps).
Storage mode could also include a discharge to the above mentioned target, if current cell voltage is above target.
Quote:
14. 4 button UI.
I think, 4 buttons for channel quick selection (and program start/stop) + 4 more buttons could be better. Only 4 button in total could result in early button fatigue if they are used extensively.
Quote:
15. 100-200-350-500mA-1000mA discharging functionality.
I would add 50mA for very small cells, and 700mA is also missing.
slmjim
slmjim's picture
Last seen: 20 hours 28 min ago
The Incurable Gadget Freak within sez,
"gottahaveitgottahaveitgottahaveit".
The Hopeless Tool Junkie within sez,
The tiny, oft-overridden percentage of Practical Thinker within asks,
"Will a 12v DC automotive adapter be included or available?
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
BlueSwordM
Ok, I came back from SecondLifeStorage, and I have some new ideas. Last features to be implemented.
@TheOnlyDocc, you came before I did. You know about 7S lithium ion battery packs? Their max voltage is 29,4V, a (5V-10V)-30V compatibility would be excellent.
@adam7027, that would be insane below 0,3A, but I get your idea.
1. Here is how I would prefer doing it:
0,05A
0,10A
0,20A
0,30A
0,50A
0,70A
0,80A
1,00A
1,20A
1,40A
1,50A
1,70A
1,80A
2,00A
2,20A
2,50A
2,75A
3,00A
2. That includes NiZn.
3. NiMH charging will throttle below 2A if it gets too hot(above 45C), and if it exceeds 60C or 1,75V, it will completely stop charging.
4. 10180 support is planned.
5. Nooo. Only one 90/120mm fan would be best.
6. These maximum charge rates have only been tested for 18650 cells.
You can set them lower obviously. Your current targets are way too low.
7. No, not exactly.
It should be: 3,5V-4,35V in 0,05V steps for all chemistries.
8. Storage mode does exactly that.
9. 4 button UI.
10. Ok for discharge rates.
Sorry if it took some time. I’m writing this on a phone.
BlueSwordM
Guys and gals, I want you to be realistic.
I want this to be the best BLF charger in terms of features, functionality, and bang for buck.
We have to be careful of feature creep.
fuzun
Last seen: 6 months 5 days ago
Interested. But I think the price point should be no more than $35.
BlueSwordM
This is where I disagree.
If we want to make the ultimate BLF charger, then not only software features will have to be implemented, but also hardware features, like nickel plated brass holders, microSD slot.
We are making a no compromise BLF charger.
primarycell
Last seen: 1 year 8 months ago
I’m very very interested in a no-compromise charger with a wide voltage input range. Cost is less of a consideration for me.
CLB
Last seen: 7 months 1 day ago
Amen. I think the target price should be no LOWER than $50, or major compromises will be certain. And, unless I am mistaken, the goal here is not a mass market product that will outsell Nitecore. I imagine any potential production partner understands that, just from the specs.
Forever
Forever's picture
Last seen: 12 hours 39 min ago
interested
OLd_gUY
OLd_gUY's picture
Last seen: 1 year 12 months ago
^ This
Pete7874
Pete7874's picture
We already have a number of cheap(er) chargers that only do some things right. If we can manage to build a charger that does everything right, to me that’s worth more. Alas, we all have different price tolerance.
Barkuti
Barkuti's picture
Very low, really. Microcontroller(s) don't need high voltage. Down to ≈5-8V without reset is easily feasible.
adam7027 wrote:
Quote:
*_11. Adjustable max voltage for lithium ion charging: 3,65V-4,35V in 0,05V steps._*
lithium-ion: 4.05V - 4.20V
lithium ion HV: 4.15V - 4.35V
Sorry but, how is the charger going to know what kind of cell is inserted?
@#$% no to those limited voltage range figures.
adam7027 wrote:
LiFePO4: 3.40V - 3.65V (I saw an article somewhere, which mentions, that at 3.4V, most of LiFePo cells are ~99% charged)
Going down to 3.4V for LiFePO4 is nice, as you say they get fully charged without need for any higher voltage.
Let me say I need no nanny in a charger. How about Let's make it with fully selectable charging voltage from 4.4V down to 3.4V. Certain functions “only for the experts” could be made accessible only after activating PRO mode by powering up the charger while keeping pressed the two main buttons. Or something sort of.
Those of you who need a nanny charger could be happier by buying something else. Don't you?
Barkuti
Barkuti's picture
Concerning the discharge feature, I agree with the big axial fan at the bottom idea. However, the charger chassis should or needs to be designed in a way that the fan's air intake may not be inadvertently interrupted. Making the charger a bit taller and setting dual air intakes each side or top and bottom definitively solves this if properly done. So be it imho
BluewordM, please edit the opening post and change the input voltage compatibility to something like 7V - 30V. Let me also say that this charger may require a very high amount of power when charging at 3A per slot, probably close to 60W. So, I believe it could be better served by a 19V - 24V power supply, similar to the ones bundled with laptops, mainly to alleviate current losses in the cable.
Sun, 08/25/2019 - 00:09
BlueSwordM
Of course. Never said that full power could be achieved with anything less than 12V.
(5-10V) is the range in which the charger will stop charging, but not completely turn off.
Mooch
Mooch's picture
Last seen: 5 months 4 days ago
Looking forward to seeing this product come to market!
Will the requirements definitions (document) address accuracy tolerances, safety features, robustness/reliability, assembly quality, QC practices, etc.?
It’s often left to the manufacturer to do this but it can cripple a product if not done well enough, or to the level expected by the community. Defining it up front can also help with the cost analysis and any necessary adjustments to the feature set or MSRP.
BlueSwordM
No worries Mooch.
I’ll be starting serious discussion with manufacturers about manufacturing and the other stuff Monday.
Say, what made you come up in this forum?
Mooch
Mooch's picture
Been a lurker at BLF for far too long!
My apologies for just diving in like that with concerns.
Barkuti posted about the charger over at ECF (electronic cigarette forums) and I was quite excited to see this project coming to light. I had to chime in to say I think it’s a fantastic idea. Smile
RobertB
RobertB's picture
Last seen: 2 days 6 hours ago
Nice to see you Mooch. Been in the e-cig forums for years. Always enjoyed your candidness with these battery manufacturers. How many years ago was the efest fiasco? lol
Barkuti
Barkuti's picture
BlueSwordM wrote:
Or maybe Banggood.
BlueSwordM wrote:
Yeah, that's one of the reasons why I want to stick with either using a 5,5*2,5mm DC input jack.
Agree. Many laptop power supplies use such standard plug, it could then be powered by a typical 19V 65W/90W brick. The charger could be sold with or without power supply at different price points. LiitoKala does this.
I for example have many “retired” quality laptop bricks which I could easily convert to ∅5.5 × 2.5mm plug if needed.
Of course what I'm trying to imply here is that, with such long list of charger features and a minimum of quality, what manufacturer is willing to make a device which such potential to cannibalize its own products? The ones who already have good chargers at beefy price points may not.
A quality charger with so many features and an expensive power brick at $49? Maybe a little more money would be more realistic. Or a tiny bit less without the brick.
LiitoKala may want to go with this. They do not have a high end charger, thus 0% chance of cannibalization. Careful negotiation may be due to make 'em understand the quality and feature requirements. Also, if they were to want to make a cut-down version later, I'd at least tell them to name it differently.
DLYFULL is also a good candidate. This would turn out to be their “flagship” charger or sort of. Careful negotiation is due too.
By the way, to ensure proper cooling of cells their slots may need some holes or slot gaps on the floor.
Sun, 08/25/2019 - 05:31; Sun, 08/25/2019 - 05:34
Mooch
Mooch's picture
OMG…that Efest fiasco. Such a fail on their part.
