Not you, someone else.
KawiBoy1428: JasonWW:Someone posted their home made version somewhere around here. They found an 18350 tube from another light and then made their own inner tube. Is that what weāre looking at or is this made by Lumintop?
Somebody? I did not find a 18350 tubeā¦I bored the tail end and machined the tube to a press fitā¦
Not too bad for being āHomemadeā I guessā¦
Was it thisā¦ā¦ā¦ā¦
Removable ring is much better.
KawiBoy1428, that looks great. Incredible work. Also, that clip is lit.
Confused on whether this short version would work on the first version of the FW3A.
Other than that I would want it to be usable with a pocket clip.
That 18350 FW3A is awfully cute!
I say with removable rubber ring
And finally it is a reality I hope
Any news when this will be available?
Agreed, rubber ring. Also hoping there will be a clip, ideally deep carry considering the shortness.
18500 ;)
perfect!
If I get some 3000mah Samsung INR18650-30Qās for this do they need to be flat top or will button top work as well?
Flat top is best. I used a button top at first and had to stretch the springs to use a flat top afterwords. Only showed the problem in turbo, manifested as a slight flicker.
Just a quick and bad photoshopping to see how it would look like with the same reduction on both sides :
Has anyone found a deep carry clip that will work yet? I really think that is all this light needs to be perfect, had the same complaint about my Zebralight.
ok, thanks, sorry for the questions, just too many pages to read through. I have a ton of button top protected cells, but 0 unprotected flats, will 3000mah Samsung INR18650-30Q fit/contact + end in opus charger without a spacer?
18500
Why does the 18350 version need an added tactical ring?
ah well, I canāt wait for answer, donāt want it to sell out at this price, Iām sure my chargers will be fine.
The only issue I see is with the tail cap. The inner and outer tubes would be replaced, but the new version apparently has shorter threads on the tube, so maybe also on the cap.
That looks MUCH better imo.
I havenāt found one yet, really wish someone would make one.
Sexy looking thing. But I have 4 x small triple/Quads now.
Wouldnāt mind one of the original clear aly ones though.
B4 the tapered body phase???.
Are there any avail anywhere??.
B4 the tapered body phase???.Are there any avail anywhere??.
That was an early prototype.
No production FW3As were manufactured without the tapered body.
