[Review] Lumintop EDC Pico
41 posts / 0 new
Mocarny
Mocarny's picture
Last seen: 4 days 9 hours ago
Lumintop EDC Pico
3 in 1 review. At the end there will be a summary for those who like only particulars, in each topic I will color the key sentences for those who read a little more, and a long waffling for everyone else. Enjoy!
For VERY large photos: click -> on the photo page right click -> "Open image in new tab"
I got the flashlight for testing from Lumintop, thanks!
I got a promotional code from Lumintop for you:
Promotion information:
Shop: Lumintoponline.com
20% discount code: LMT205
(Usable when an order amount is over $ 19)
Code end day: Dec. 31, 2019
Table of Contents:
- General parameters
- Package content
- Appearance, parameters
- UI, runtime and charging
- PWM
- Waterproof
- Dustproof
- Light pattern, tint
- Usage and my experience
- Gallery
- Summary
General parameters
Straight from the manufacturer:
1. uses OSRAM GW PUSRA1 LED with 50,000 hours of life
2.2 modes with max 130 lumens output and up to 7.5 hours working time (7.5 hours?)
3. Micro USB rechargeable battery with built-in charging indicator
4. Built-in 3.7V / 80mAh Li-ion battery, fully charge in 57 minutes
5. Tiny and lightweight design, 41.5mm long and 11.8g weight
6. Three optional colors, black, silver and pink
7. Bead surface optical lens creates a soft and beam balance
Package content
A standard gray cardboard box with a flashlight drawing, business address on the back, phone number, e-mail and some stamps, i.e. things that nobody cares about.
Inside quite a rich set, because in addition to the flashlight we get:
- mini carabiner for keys
- micro USB cable
- user manual
- o-rings
O-rings everywhere, they add them to everything.
Weight: 16,6g
Size: 41,5mm x 13,5mm
A small light with a good-looking, square texture, company logo, name and hole for key ring.
From left to right:
- Head with a green o-ring glowing in the dark,
TIR optics, such a honeycomb
And it diffuses light well. From the inside from the diode side you can see the thread and these two holes, the possibility of unscrewing, repairing, modding. Well, maybe not modding, but you can fix it when needed.
- Second part with well-lubricated thread, O-ring, 80mAh Li-Ion battery, micro-USB port and space for a key ring.
General info:
Simple UI, tightening the head to a certain point enables the first mode (15lm), tightening even more - the second mode (130lm)
Runtime
Hi mode
About 25 minutes until the brightness drops below 10%, but the actual lighting time at a reasonable brightness is 20 minutes.
Low mode
260 minutes until the brightness decreases drastically, after 300 minutes (5 hours) it is less than 10%
Charging
Built-in charger with micro-USB port, charging time 46 minutes. Information about charging by a red LED, about charging - by green.
Capacity about 51mAh, checked with my USB charging...thing (Keweisi). It's less than the declared 80mAh. I take the correction for the inaccuracy of my tests (I doubt with such a big difference), which doesn't matter too much, considering the good runtimes. In other words - no matter how much capacity it has, we care only about runtime.
PWM
I didn't notice any
Waterproof
I wasn't sure if the IP68 was tested with the head fully tightened (i.e. max mode) or slightly tightened (i.e. turned off as we would normally carry it). When it is turned off, there is some space... (photo unscrewed - tightened)
which raised my concerns during testing.
Aquarium test: Flashlight left for 2 hours
Shines. But since this test (swimming 5 hours) survived a $1 flashlight, nothing will surprise me anymore.
Because the EDC Pico is a pocket flashlight, it's more likely that we forget to take it out of our pants or jacket and wash it in the washing machine.
Let's see if it will work
Despite this slight space (because it was turned off), it survived the test and still works. It smells really good now. Smile
Dustproof
IP68 (not only IPX8) in this case is important because you always have dust, sand or other things in your pocket.
I didn't have perfect way to check it, so I thought I'd put it in a vacuum cleaner bag and vacuumed it a bit.
And with such a beast at home, the test will certainly not be light
Heh...
Ahem... well, I dusted the whole house, everything and very thoroughly. It looks like this after the test
Lots of fine dust, a grain of sand, but nothing got further than to the o-ring. So the test passed. It had to be cleaned later. Such advice, do not put the flashlight into the vacuum cleaner too often, something always gets dirty with grease or the O-ring with this dust and you will need to replace it faster.
Light pattern, tint
White balance: sunlight
From left to right: Lumintop EDC Pico - Lumintop IYP07 - $1 flashlight
The black dot in the center is the center of the beam, each line with an interval of 15cm. You should see everything enlarged.
Pico EDC has the widest beam, the most diffused and even light. Cold white does not bother me personally.
Well, a flashlight with such small dimensions and weight will definitely be with us in most everyday situations.
It's so small and light that you don't even feel the difference whether it is or not.
And you can, for example, shine when opening the door (low - hi)
You know, you can also attach something bigger
You know...
Now you can clearly see where the lock is
(Door started to burn eventually)
You can shine when you walk in the stairs, sometimes I don't turn the main light on on purpose ... I always hope that I will not meet any of the neighbors:
- Good morning, our light does not work?
- Good morning, no, it ... it works, only this ... because the flashlight ... and it's ... cool, right...? Heh ...
- Ekhm ... I'll go goodbye.
(low - hi)
Recently, I came up with idea it to shine it in a letterbox, I always had a problem with it to see if something is there.
Applications could be listed for a long time, because if we have it in pocket, it can always be useful.
Well, maybe I will tell you about this charging and USB. A good idea, but while charging, we have two parts separately, a head and a battery, so the first one can get lost and we should be especially careful.
When it comes to durability, it was carried for 2 weeks in a bag, pants with keys, everyday and everywhere, and it has already scratched a bit.
I think that the silver version would have the least visible scratches.
Gallery
Summary
In the minimalistic cardboard box we get a mini EDC flashlight with a built-in battery, rechargeable via micro-USB. The set has everything to start with - a key clip, user manual, spare O-rings and a micro-USB cable. EDC Pico is resistant to submerge, splashing, accidental washing in the washing machine and sanding, so you can take it in any conditions. Thanks to 2 modes and (operating time) the flashlight becomes even more universal. A diffused and even light with a cold tint, which, however, does not disturb, because it is a flashlight for temporary shining. We have 3 colors to choose from, and the set contains everything to start, which suggests that you can present such a flashlight.
"If you start assessing a fish for its ability to climb trees, it will think for the rest of its life that it is stupid." - well, so if you evaluate this lantern as a pocket key used max one minute a day, it is great.
Pros:
- small dimensions and weight
- 2 modes
- charging via micro-USB
- even, diffused light
Cons:
- cold white light
Rating: 9/10
I hope you enjoyed!
If you struggle choosing your perfect headlamp, check my headlamp guide, I compared 15 most popular headlamps there: CLICK
Edited by: Mocarny on 08/28/2019 - 15:38
Rdubya18
Rdubya18's picture
Last seen: 4 hours 18 min ago
Nice review ! Pretty sure that’s the first one I’ve seen tested in the vacuum cleaner ! LOL
djozz
djozz's picture
Last seen: 4 hours 40 min ago
Thanks for the review, this is a nice addition to the long list of flashlights in this format (I have a copper CooYoo on my keychain).
Quote:
Size: 41,5cm x 13,5cm
This is larger than it seems from the pics though Wink
Mocarny
Mocarny's picture
Yeah, it is pretty big! Cool
arek98
Last seen: 1 day 2 hours ago
Zakrzówek??
Mocarny
Mocarny's picture
arek98 wrote:
Zakrzówek??
Uch where is that? LOL I can’t find it Facepalm
DavidEF
DavidEF's picture
Last seen: 1 week 4 days ago
Nice review! It’s a cute light, but I’d prefer a smooth TIR instead of the honeycomb. I do like the integrated charging with indicator lights. The included mini carabiner is a nice touch as well.
- The YKK Philosophy
Mocarny
Mocarny's picture
I don’t have pictures, but it can throw a bit, more than I expected from this TIR, like the perfect balance for me Smile
Without this carabiner it would sit on my shelf and rest with other lights Silly
Rdubya18
Rdubya18's picture
I like that carabiner also . I may have to get one of these and give my worn looking i1R to my girlfriend ! Wink
1stein
1stein's picture
Last seen: 8 hours 29 min ago
Great review, yet a witty one. Obviously much time and heart put in but worth the effort. I’ve read from the very beginning to the very end almost holding my breath. This is a good proof for that you don’t need tons of sophisticated devices to make a review interesting and pleasant in reading.
Chapeau Bas!
MascaratumB
MascaratumB's picture
Last seen: 48 min 13 sec ago
Another good and funny review Wink
Good work!! Wink
And the vacuum cleaner test is priceless Big Smile
JasonWW
JasonWW's picture
Last seen: 1 day 5 hours ago
Some pictures show the light tail standing. Is the key ring hole in the back removable? Maybe it is 2 different versions?
Mocarny
Mocarny's picture
It can’t tail stand, because of this attaching hole. There is only one version as far as I know.
It is integrated, but you know, you can remove this attaching hole, if you really want to Wink
JasonWW
JasonWW's picture
Do you mean it’s threaded into place or you would have to cut it off?
arek98
It is old quarry in Kraków, I thought your pictures were taken there.
Mocarny
Mocarny's picture
Nice place, it is always good to know what is in my country Silly But I'm from Kielce.
You have to cut it off. But...
Or wait
Just a few tries, and if you really want it can tail stand Smile
DavidEF
DavidEF's picture
Or, get a ring magnet that fits around the bump, and glue it in place. Then you can have tail stand AND tail magnet! I don’t have one of these lights, so I don’t know what the dimensions should be. But I got one of the Olight Tan i3e lights, and someone asked about tail stand for that one. I looked at K & J Magnetics and they did have one the right size for the Olight. They probably have one that will fit this light too. It might even be the same size.
Mocarny
Mocarny's picture
But why someone would need tail stand in such small light?
DavidEF
DavidEF's picture
Some people use tiny lights and/or not-so-bright lights to go to the toilet at night. So, maybe tail stand is for when you’re sitting on the pot and don’t want to have to hold the light while doing your business? I’m sure there are other uses as well. Just thought of that one first. Big Smile
RelakS
Last seen: 5 days 5 hours ago
I have an Astrolux M01, but it is an almost useless flicker party. What about with this light? I assume it is ok because no flicker is mentioned in the test.
So, my question is: if the battery dies, can it be changed, like in the Astrolux? Lumintop’s page says it have a 10180 battery, but is it welded/soldered/glued in, or replaceable?
Mocarny
Mocarny's picture
There is no noticable pwm even on the camera.
Battery isn’t replacable, it is integrated part, so when it dies, it dies. But I wouldn’t worry about it, everything seems good quality, so battery should last reasonably long.
Terry Oregon
Terry Oregon's picture
Last seen: 2 days 3 hours ago
Thanks for the review. Got mine back in May, directly from Lumintop, right after it became available. Chose pink for something different. If it had been really really pink, I would not have chosen that color.  But it's more like rose gold.
It can actually tail stand - if you don't mind fiddling with it for a few seconds.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
Mocarny
Mocarny's picture
Nice rosy color Cool
For that “toilet use” with tail standing that DavidEF mentioned, I’d choose IYP07 if I can choose from Lumintop.
phouton
Last seen: 11 hours 56 min ago
Mocarny Thanks for this review. I loved the humor and the flashlight!
Have you checked the parasitic drain on it? How long does it hold a charge? Some reviews mention that the battery is flat after as little as 24h, which would make it useless! https://zeroair.org/2019/06/25/lumintop-edc-pico-keychain-flashlight-rev...
JasonWW
JasonWW's picture
I think I see the problem.
Lights like this that twist to connect power have zero parasitic drain. When you twist it Off, the battery is not connected at all.
What Zeroair is refering to in his review is a drain due to leaving the charging cable attached. It’s as if the charging circuit does not go to sleep after it’s fully charged.
If you charge it and then remove the plug there will be zero parasitic drain so the light is fine.
If you charge it and don’t remove the plug there will be the drain.
His charging circuit might be defective or it might be it is just designed poorly. There is also the possibility that the 10mA draw he saw on his usb power meter was a draw between the charging circuit and the usb plug. Meaning the charging circuit is not pulling power from the battery at all. This would make it a non-issue.
Unfortunately, you can’t check the actual parasitic drain due to the sealed battery. My guess is it’s zero. I doubt they would design a flashlight that self drained in 24 hours.
phouton
Hmm, that’s a plausible explanation. Unfortunately since the charging circuit is inside the battery side of the light’s body, it’s conceivable that it might still be draining the battery even with the head not connected, no?
Ultimately it would be best to hear from owners on how long it retains a charge.
d_t_a
Last seen: 10 hours 13 min ago
Ok, maybe that could be an explanation… but I also got the EDC Pico — I got 2 actually, a black and a pink.
The black one has the exact same issue mentioned by ZeroAir (and also in another post I visited), the battery self-drains in about 1 day, after charging it. The charging cable is NOT plugged in the EDC Pico after I finish charging it. I just let it stand (even with the head off), and the battery self-drains.
This occurs on 1 unit. The other unit EDC Pico doesn’t have this issue (at least it won’t self drain completely after several days of not using the light).
But based on the number of EDC Pico with this issue, I would think there is some real issue about the battery self-draining, but unfortunately I don’t know how to troubleshoot it..
phouton
Thanks for reporting. The inconsistent quality is quite disappointing. I would hope it could last months without recharging. I quite like the design and form factor.
There are many other brands that have essentially the same design but with different bodies and emitters. I wonder if they are similarly affected. Olight i1R, Wuben G series, Trustfire Mini2, Acebeam M50, and probably several others.
JasonWW
JasonWW's picture
Wow, that sounds bad. Definitely is unusable. I wonder how many units are defective like this. Have to talked to them about getting refund on it?
JasonWW
JasonWW's picture
I like the Jaxmnve M1. I have several with no issues, but they don’t have the super bright mode like the pico. They are also a bit tricky to find as their store on Aliexpress isn’t there anymore.
Mocarny
Mocarny's picture
So my Pico doesn’t have that problem, I charged it long time ago and it works fine. So yours may be defected.
And yes, when charging cable plugged in after finishing charging, battery drains itself quickly, even after 2h with that cable plugged in and a green diode shining, you can unplug it and plug again and it will shine red and charge.
