it has earned a spot on my mouse pad,
The tint is good during the day
and being twice as bright as my sw45k, cant be bad
respect the 351
of note
all the other lights in my edc rotation are 219b
this 351 is the only outsider to make the cut
I particularly like the pebbled tir beam, very even, useful at close range
efficiency test
with a depleted Eneloop AAA at 1.2v in the Tool that contactcr built w LH351s I got 55 lumens on max.
The same battery in my copper tool, powering an sw45k, gave me 25 lumens…
so yes, the LH351d Is indeed twice as bright as the sw45k… wow…
Looks like MTN has restocked 4000K +90CRI LH351D’s (bare LED). Anyone know if these are the same as the Digikey ones? P6 flux bin, doesn’t say what CCT bin, I’m thinking it might be the same TP quarter bin.
dont know the answer to your questions, but here are some visuals, for reference
the light in the middle thanks to contactcr
max output reference:
the Cu eTool makes 110 lumens with a 4000k 219c or with a 6000 xp-g2, and it is supposed to make 80 lumens w a 219b 4000k
I was checking to see if there was an obvious difference in “efficiency” as expressed as max lumens on Hi. Albeit the hosts are not identical, they all came suprisingly close to the same outputs, on my light meter, calibrated to an HDS:
73 lm 219b 4.5k Cu Tool w reflector, very pink during the day
72 lm LH351d 5k Aluminum Tool aaa w tir, very neutral during the day, but looks pink compared to optisolis and looks yellow compared to 219b… iow tint is relative
67 lm optisolis 6k JetU w pebble tir, slightly green during the day
clemence is the master of TiR and cherry picked the one he put on the JetU, I dont know his secrets, maybe ask, or maybe contactcr already can tell you…
Digi-Key “dog fart” arrived. It’s almost identical to the Arrow one tested except for about 100K higher CCT ~4800K instead of ~4700K. Duv is otherwise the same.
How does the LH351D 90cri compare to a nichia 319A (80cri) in terms of efficiency and beam pattern? Thinking about swapping to a higher CRI LED in my Quark Mk III…
the higher CRI LED will be less “efficient”, inasmuch as it will produce less total lumens
CRI, and especially CRI R9 go up at least as much as lumens go down
imo, it is worth the trade.
now, depending what CCT you are interested in
there may be reasons to choose 219b over LH351d or SST-20
Im not sure yet, which I would prefer, have not tried the SST for example
I do like the Nichia more than the unsliced LH351d…
for my pink biases the LH351d needs to be sliced,
that also comes with a lumen penalty
If the die of the 319A is close to that of the 219C, the LH351D will be floodier but probably still have more output/be more efficient even binned at 90CRI. The LH351D has a die size right between the XP-L and XM-L2 IIRC.
I’ve actually become quite fond of the 4000k sst-20 but I believe those would be even less efficient than the LH351D. I have a few lights with that and while the r9 does lack a bit it seems overall quite nice. I’d really like to keep this as bright as possible and the 319 is doing alright for now… just love my high cri options!
I think you might have a 319a D340, if thats true, and you go to a sw45k D220… you would see a 35% lower output… sounds like you might not like that… but
let me play CRI advocate…
say your light makes 340 lumens now
and with a sw45k, lets say it “only” makes 220 lumens
the low CRI is only 54% brighter… that is not really a big visual difference
and you give up all Red rendering… to get those extra 120 lumens… is it worth it?
you know best…
lucky for you, that version of the quark is not glued… tinker on!
The Samsung LED still has better cri and r9 than the natural light coming in my office today:
Two measurements taken in Texas, today at 2:45PM, overcast day. First is indoors with no artificial light, only ambient light from window - the next measurement is when I step outside.
