13665 posts / 0 new
Johm
Last seen: 2 weeks 3 days ago
There is no more information on the FW1A at this time.
You don’t have to go to facebook for info on this, i’m pretty sure all information will appear in this forum as soon as it is available.
JasonWW
JasonWW's picture
Last seen: 1 day 7 hours ago
scosgt wrote:
FW3 was my favorite light when I got it.
Then my Fire Flies E01 showed up.
I really love this light
only 1” longer, lit side switch, the throw on it is great. Rivals an L6. Not in total lumens of course, but the narrow beam penetrates like crazy. AND it can stay on turbo for a long time, handles heat very well.’
Too bad they stripped down the UI.
Isn’t that light much larger? It’s 21700 sized.
The Lumintop EDC18 should be the side switch version of the FW3A. Same size, but can use protected cells, same UI, same Leds, lighted side switch, deep carry pocket clip, magnet in tail, etc…
scosgt
JasonWW wrote:
scosgt wrote:
FW3 was my favorite light when I got it. Then my Fire Flies E01 showed up. I really love this light only 1” longer, lit side switch, the throw on it is great. Rivals an L6. Not in total lumens of course, but the narrow beam penetrates like crazy. AND it can stay on turbo for a long time, handles heat very well.’ Too bad they stripped down the UI.
Isn’t that light much larger? It’s 21700 sized. The Lumintop EDC18 should be the side switch version of the FW3A. Same size, but can use protected cells, same UI, same Leds, lighted side switch, deep carry pocket clip, magnet in tail, etc…
I don’t pocket carry – pockets are full of guns, shield case and so on.
In a small belt holster, the difference in size is negligible, and the weight is about the same.
The E01 will run way longer on high, the FW3 quickly becomes too hot to hold.
The E01 has a narrow well focused beam, which has a throw that rivals an L6, while the FW3 is totally flood.
That being said, I have like 5 of the FW3 lights and they are great, the copper is stunning.
But I find the E01 more useful.
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 4 months ago
trakcon wrote:
FW3A, but with a single emitter and reflector design instead of a TIR optic.
Are we sure it’s got a reflector and not a single TIR?
KevinZA1988
KevinZA1988's picture
Last seen: 1 month 5 days ago
If it has a reflector, I really hope it’s the same size as easily available Yajiamei Optics. Iove playing with optics and different LED’s.
Don’t like the stupid ring around your LH351D beam in a reflector? Pop on a beaded optic. Enjoy the magic!
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manker MC13, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
cabfrank
Last seen: 10 hours 59 min ago
I would probably prefer a single TIR optic, but I’m excited about either.
mattlward
mattlward's picture
Last seen: 5 hours 53 min ago
I was hoping for a TIR as well, will have to see what fits.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
cabfrank
I’ve always liked the large hotspot in good single TIR lights. We will have to wait and see. I wonder which LED will be used, and how bright it will be.
contactcr
Last seen: 6 hours 19 min ago
Maybe they can use a big fat MCPCB like in the Ti model and fit a TIR or reflector by just swapping MCPCB size. Wishful thinking…
Chronoscape
Last seen: 1 month 11 hours ago
scosgt wrote:
Harbor Freight sells an assortment cheap.
https://www.harborfreight.com/225-piece-nitrile-o-ring-assortment-67677....
https://www.harborfreight.com/382-piece-o-ring-assortment-67554.html
https://www.harborfreight.com/225-piece-metric-nitrile-o-ring-assortment...
https://www.harborfreight.com/397-piece-metric-o-ring-assortment-67580.html
Those are all way too big to replace the pocket clip/inner tube o-ring. According to my measurements I think they are around 18mm x .5mm. I have no idea where to source them, but now I need two. And any bigger, the light won’t work. Facepalm
Rayoui
Rayoui's picture
Last seen: 31 min 19 sec ago
So I just got a second OG gray FW3A from Amazon because the deal with a coupon code was too good to pass up. As soon as I picked it up I noticed it felt different in the hand. The anodizing is noticeably smoother and slick on the new unit. The knurling pattern on the head and tail is also much shallower and feels smoother to the touch. The tail button in the new unit is slightly less tactile when both are pressed dead center but when pressed off center, the older one gives a slightly mushy feedback while the newer one retains its click.
Nothing bad about the changes, though I think I do slightly prefer the more matte hand feel of the older unit.
Click the photo for higher resolution (8067×5472).
justanotherguy
Last seen: 11 hours 19 min ago
amazon coupon code?
I need one for a neighbor
Scallywag
Scallywag's picture
Last seen: 1 hour 39 min ago
I pre-ordered a purple unit from Neal, and tracking currently shows it to be delivered Tuesday 9/3.
Rayoui
Rayoui's picture
justanotherguy wrote:
amazon coupon code? I need one for a neighbor
I’m reasonably sure the code is expired now, but keep an eye on this thread to see if another one pops up.
justanotherguy
Thanks.. On Reddit, I found illumn.com is having a 0 or 25% sale
Lick
Lick's picture
Last seen: 1 month 6 days ago
I purchased a FW3A on 6/23 but the tracking number Neal gave me didn't work and he never replied to my email. What is the best way to contact him?
hodor
hodor's picture
Last seen: 13 hours 55 min ago
Don’t worry, he’ll sort you out. You can pm Neal here . Also, I hear he replies pretty quickly on Facebook messenger if you have access to that.
justanotherguy
are the copper ones coated now??
I opened mine, washed it and attempted to force patina with baking soda and warm water. The effect was negligible after 4 hours.
like zero effect.
I thought it would be easier
BlueSwordM
BlueSwordM's picture
Last seen: 3 days 11 hours ago
Try something much stronger: citric acid/vinegar + salt.
Remove it from the solution, and let it air dry.
If this doesn’t oxidize it, then it is coated.
hodor
hodor's picture
Haven’t seen it mentioned here yet… Neal posted on TLF saying 21700 version is also in the works!
justanotherguy
Ill try some more, Just acetone’d it….
cdjaney
cdjaney's picture
If someone could respond….couldn’t find answer.
Curious…is the “candle” strobe/flicker (and lightning) mode adjustable in brightness? Or is it preset like most blinkies?
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
jasontheguitarist
Last seen: 3 hours 45 min ago
cdjaney wrote:
If someone could respond….couldn’t find answer. Curious…is the “candle” strobe/flicker (and lightning) mode adjustable in brightness? Or is it preset like most blinkies?
You can hold to increase and tap hold to decrease brightness just like in the normal mode.
cdjaney
cdjaney's picture
That is TOOOOO Awesome! Thanks for the reply!
Rayoui
Rayoui's picture
Brightness in candle mode can be set by tap and hold. Strobe modes have only adjustable speed. Lightning mode has no adjustments (brightness varies on its own).
mk23
Last seen: 5 days 4 hours ago
There’s a sale going on at my local store so i ordered one FW3A.
My light has a brass driver retaining ring, black pocket clip, Lumintop one piece optic and the most important detail is the tail
cap has been glued tight.
The light work flawlessly though, I just wish that i got the one using Carlo optic.
Geuzzz
Geuzzz's picture
Last seen: 11 hours 35 min ago
are the copper ones coated now?? I opened mine, washed it and attempted to force patina with baking soda and warm water. The effect was negligible after 4 hours. like zero effect. I thought it would be easier
Put it overnight in a bag with smashed hard boiled eggs.
Patinas like crazy.
JasonWW
JasonWW's picture
That sounds odd. They now have the retaining ring for the tail so glue is not necessary. The black clip is definitely an early part. I thought they had fully switched to silver clips before they started using the one piece optic.
Do you see the traces of glue or is it still together and too tight to remove? I have not heard of them gluing any tails. Quite odd.
Maybe the store added the glue to reduce warranty issues?
mk23
There is trace of glue on the pocket clip and the inner tube is pretty much stuck inside the body as well so i think there’s a good chance that it has been glued. I’ve also checked with the store, they said all their FW3A have been glued like this from the factory but only in their recent batch and not on the earlier ones.
Scallywag
Scallywag's picture
Received my purple edition today (thanks ToyKeeper). Worked great out of box – I opened it anyway, it has a black retaining ring in the tail, silver clip, and a brass retaining ring in the head. I forget how to check the Anduril version (well, I forget how to check for the manual memory or two-step lockout mode). Also has a glass lens and Carclo optic.
I went with the SST-20 4000K for this one, and I’m not noticing any green, so it’s a pretty good tint. The button doesn’t feel better or worse than I recall the button being on my original, group-buy edition FW3A.
Fake edit: Checked, and it does have a two-step lockout mode. I don’t remember other details to check for, or what Anduril version that indicates.
